Masks not matching
    Masks not matching
    UltraJones,
    Cleaning up the last little bits from my conversion to HS3. I have not been able to get the number or name block to work since conversion. Here is a sample of a call that came in a couple of days ago:
    May-09 11:24:55 AM Informational Ring of existing call detected ...
    May-09 11:24:49 AM Informational Ring of existing call detected ...
    May-09 11:24:43 AM Informational Ring of existing call detected ...
    May-09 11:24:37 AM Informational Ring of existing call detected ...
    May-09 11:24:33 AM Informational Incoming call from NAME NOT FOUND 1 (876) 487 1678
    May-09 11:24:31 AM Informational New incoming call detected ...
    If I set the block flag on numbers that are in the database it works perfect. Here is my current mask. I went back and put in exactly what I had in HS2 as well as simplifying to what I have now as shown in the attachment. I would have thought it would have matched "NAME NOT FOUND"
    Thoughts?
    Is "NAME NOT FOUND" being returned from the incoming Caller Id?
    Ultrajones
      Yes, I think so... I just turned up the log to debug. Will wait and post the next one it misses.
      **Edit ** Changed the log flag to debug and tested with a call... got this in the log :
      May-26 8:09:57 PM Event Event Trigger "Caller ID Announce"
      May-26 8:09:57 PM Informational Incoming call from CHRIS 1*********
      May-26 8:09:56 PM Informational New incoming call detected ...
      Odd... checked the config file and it was set to 8 and reflected so in options screen
      thinking that the config file might have some lint from HS2 deleted it and restarted HS3. Config file re-created but no mask section
      Same result... can't seem to get it into debug logging level.
      Here is where I am just now (notice there is no CallerAttr section):
      [Settings]
      Version=3.0.5622.16942
      [Interface]
      Serial1=COM5
      [Options]
      LogLevel=8
      Here is the config file before I deleted and restarted:
      [Settings]
      [Interface]
      Serial1=COM5
      [CallerAttr]
      NameBlockMask=(IN|TOLL|NAME NOT FOUND|O^)
      Announce=0
      NmbrBlockMask=^8(00|88|77|66)
      [NmbrFormat]
      11=# (###) ### ####
      [Options]
      LogLevel=8
      Thank you,
      Chris
