Hello,
I installed a switch AeonLab DSC18103 G2 in 2016 on my network zwave with the plugin 3.0.1.25. Everything was OK, the devices Volts and Amperes were updated. Over time, I made the plugin update: 3.0.1.80, 3.1.0.87, 3.0.1.93, 3.0.1.124, and 3.0.1.130.
I have just discovered that my two devices (Volts and Amperes) were no longer updated.
I excluded the swiwch from my network and included it with the latest version of the plugin (3.0.1.130). My two devices (Volts and Amperes) are no longer updated, the values remained at 0.
I reinstalled version 3.0.1.25 of the plugin, excluded and included the switch of the network zwave, and my two devices (Volts and Amperes) have been updated again (see below)
Rich can it inform me about the removal of this function on the switch DSC18103
thank you in advance
I can't stay in plugin v3.0.1.25 because i have a lot of error on other device (Fibaro FGS-223, etc....)
Jean-Francois.
____________________________________________________________ _______________________
Plugin V3.0.1.130
juin-22 15:02:34 Z-Wave Device: Node 49 Z-Wave kW Hours Set to 0,005 (0,005 kW Hours)
juin-22 14:57:51 Z-Wave Device: Node 49 Z-Wave Watts Set to 10,156 (10,156 Watts)
juin-22 14:52:34 Z-Wave Device: Node 49 Z-Wave kW Hours Set to 0,004 (0,004 kW Hours)
juin-22 14:45:08 Z-Wave Device: Node 49 Z-Wave Watts Set to 10,691 (10,691 Watts)
juin-22 14:45:06 Z-Wave Device: Node 49 Z-Wave Switch Binary Set to ON
juin-22 14:28:59 Z-Wave Device: Node 49 Z-Wave Watts Set to 0 (0 Watts)
juin-22 14:28:58 Z-Wave Device: Node 49 Z-Wave Watts Set to 5,554 (5,554 Watts)
juin-22 14:28:56 Z-Wave Device: Node 49 Z-Wave Switch Binary Set to 0
juin-22 14:28:21 Z-Wave Device: Node 49 Z-Wave Watts Set to 10,48 (10,48 Watts)
juin-22 14:28:20 Z-Wave Device: Node 49 Z-Wave Watts Set to 9,834 (9,834 Watts)
juin-22 14:28:19 Z-Wave Device: Node 49 Z-Wave Switch Binary Set to ON
juin-22 14:25:13 Z-Wave Device: Node 49 Z-Wave Watts Set to 0 (0 Watts)
juin-22 14:25:12 Z-Wave Device: Node 49 Z-Wave Watts Set to 5,965 (5,965 Watts)
juin-22 14:25:11 Z-Wave Device: Node 49 Z-Wave Switch Binary Set to OFF
juin-22 14:22:34 Z-Wave Device: Node 49 Z-Wave kW Hours Set to 0,002 (0,002 kW Hours)
juin-22 14:21:10 Z-Wave Device: Node 49 Z-Wave Watts Set to 10,603 (10,603 Watts)
Plugin Version 3.0.1.25
juin-22 14:13:49 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 14:13:49 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,414 (235,414 Volts)
juin-22 14:08:43 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,019 (0,019 Amperes)
juin-22 14:08:43 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,957 (234,957 Volts)
juin-22 14:03:35 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,417 (235,417 Volts)
juin-22 13:58:28 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,061 (236,061 Volts)
juin-22 13:53:21 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,459 (235,459 Volts)
juin-22 13:48:14 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,168 (236,168 Volts)
juin-22 13:43:05 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 13:43:05 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,725 (236,725 Volts)
juin-22 13:37:58 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,019 (0,019 Amperes)
juin-22 13:37:58 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,528 (235,528 Volts)
juin-22 13:32:51 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,925 (235,925 Volts)
juin-22 13:27:45 Z-Wave Device: Node 49 Z-Wave Volts Set to 237,032 (237,032 Volts)
juin-22 13:22:38 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,719 (235,719 Volts)
juin-22 13:17:31 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,417 (236,417 Volts)
juin-22 13:12:25 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,165 (236,165 Volts)
juin-22 13:07:18 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 13:07:18 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,095 (236,095 Volts)
juin-22 13:02:11 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,242 (235,242 Volts)
juin-22 12:57:05 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,84 (234,84 Volts)
juin-22 12:51:58 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,019 (0,019 Amperes)
juin-22 12:51:58 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,193 (235,193 Volts)
juin-22 12:46:51 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 12:46:51 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,152 (236,152 Volts)
juin-22 12:41:43 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,671 (234,671 Volts)
juin-22 12:36:37 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,151 (235,151 Volts)
juin-22 12:31:30 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,54 (234,54 Volts)
juin-22 12:26:23 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,315 (233,315 Volts)
juin-22 12:21:16 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,671 (234,671 Volts)
juin-22 12:16:09 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,723 (234,723 Volts)
juin-22 12:11:02 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,019 (0,019 Amperes)
juin-22 12:11:02 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,065 (234,065 Volts)
juin-22 12:05:55 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 12:05:55 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,767 (234,767 Volts)
juin-22 12:00:48 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,019 (0,019 Amperes)
juin-22 12:00:48 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,649 (233,649 Volts)
juin-22 11:55:41 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,761 (233,761 Volts)
juin-22 11:50:34 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,715 (235,715 Volts)
juin-22 11:45:27 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 11:45:27 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,87 (235,87 Volts)
juin-22 11:40:21 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,404 (235,404 Volts)
juin-22 11:35:14 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,009 (234,009 Volts)
juin-22 11:30:07 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,131 (234,131 Volts)
juin-22 11:25:00 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,792 (235,792 Volts)
juin-22 11:19:53 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,109 (235,109 Volts)
juin-22 11:14:47 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,534 (233,534 Volts)
juin-22 11:09:40 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,825 (233,825 Volts)
juin-22 11:04:33 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,662 (235,662 Volts)
juin-22 10:59:27 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,96 (234,96 Volts)
juin-22 10:54:20 Z-Wave Device: Node 49 Z-Wave Volts Set to 231,877 (231,877 Volts)
juin-22 10:49:13 Z-Wave Device: Node 49 Z-Wave Volts Set to 232,487 (232,487 Volts)
juin-22 10:44:07 Z-Wave Device: Node 49 Z-Wave Volts Set to 231,722 (231,722 Volts)
juin-22 10:38:59 Z-Wave Device: Node 49 Z-Wave Volts Set to 231,253 (231,253 Volts)
juin-22 10:33:52 Z-Wave Device: Node 49 Z-Wave Volts Set to 231,866 (231,866 Volts)
juin-22 10:28:46 Z-Wave Device: Node 49 Z-Wave Volts Set to 232,112 (232,112 Volts)
juin-22 10:23:39 Z-Wave Device: Node 49 Z-Wave Volts Set to 231,832 (231,832 Volts)
juin-22 10:18:33 Z-Wave Device: Node 49 Z-Wave Volts Set to 231,87 (231,87 Volts)
juin-22 10:13:26 Z-Wave Device: Node 49 Z-Wave Volts Set to 232,383 (232,383 Volts)
juin-22 10:08:18 Z-Wave Device: Node 49 Z-Wave Volts Set to 232,87 (232,87 Volts)
juin-22 05:22:02 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,923 (233,923 Volts)
juin-22 05:16:55 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,137 (234,137 Volts)
juin-22 05:11:49 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,768 (234,768 Volts)
juin-22 05:06:42 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,656 (233,656 Volts)
juin-22 05:01:35 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,019 (0,019 Amperes)
juin-22 05:01:35 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,231 (234,231 Volts)
juin-22 04:56:29 Z-Wave Device: Node 49 Z-Wave Amperes Set to 0,02 (0,02 Amperes)
juin-22 04:56:29 Z-Wave Device: Node 49 Z-Wave Volts Set to 236,121 (236,121 Volts)
juin-22 04:51:22 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,597 (234,597 Volts)
juin-22 04:46:15 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,802 (234,802 Volts)
juin-22 04:41:09 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,434 (234,434 Volts)
juin-22 04:36:02 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,981 (234,981 Volts)
juin-22 04:30:55 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,53 (234,53 Volts)
juin-22 04:25:48 Z-Wave Device: Node 49 Z-Wave Volts Set to 234,74 (234,74 Volts)
juin-22 04:20:41 Z-Wave Device: Node 49 Z-Wave Volts Set to 233,855 (233,855 Volts)
juin-22 04:15:33 Z-Wave Device: Node 49 Z-Wave Volts Set to 235,277 (235,277 Volts)
Plugin V3.0.1.130
