Hey guys,
I have used HS for about 2 years with no problems. Not as heavy duty as some as you, but it is still a great convenience for me.
Homeseer does not seem to be sending (or my modules are not receiving) a signal any more. When I start HS it says that it has initialized my cm11A. But when I go to devices and select execute-command-off, nothing happens.
I have tried:
- unplugging the cm11a
- moving the cm11a to a new plug
- resetting the memory under the interfaces tab
- setting the interface device to none then restart HS. The add back the cm11a and restart HS....nothing.
It says that it sees it though, so I don't know what could be wrong. I have not added anything new (TV, microwave...). I would think if the cm11a was bad, that it would not be able to initialze...
Any ideas....
Don
I have tried:
Any ideas....
Don
