How to manually reset your Zee's network settings
    NOTE: For the Zee S2 you can reset your network settings by pressing the "r" key on an attached USB keyboard then press ENTER. Do this when the LED on the unit turns yellow.
    So you changed the IP address of your Zee from within HomeSeer. Maybe you set the wrong IP or other setting and now you cannot access your Zee over the network. If you have an HDMI monitor and USB keyboard you can manually change the settings back, here is how.
    1. Connect an HDMI monitor and USB keyboard to your ZEE.
    2. Power cycle the Zee. You should see startup messages on your monitor and after about 20 seconds you should get a login prompt. Login with user=HomeSeer or user=homeseer and the password should be whatever password you changed your Zee to. If you did not change it, the default is password=hsthsths3.
    3. After you log in change to the folder where the network settings using the command: cd /etc/network
    4. Now edit the interfaces file with the command: sudo nano interfaces
      This will start a simple text editor.
      The interfaces file should look like this for DHCP:
      auto lo
      iface lo inet loopback
      iface eth0 inet dhcp
      address 192.168.2.249
      netmask 255.255.255.0
      gateway 192.168.2.1
      allow-hotplug wlan0
      iface wlan0 inet manual
      wpa-roam /etc/wpa_supplicant/wpa_supplicant.conf
      network 0.0.0.0
      address 0.0.0.0
      gateway 192.168.1.1
      iface default inet dhcp
    5. For static change "dhcp" to "static" and make sure the address, netmask, and gateway are set properly.
    6. To save your changes press Control X, then Y, then hit return.
    7. Now restart the unit to test your changes, enter: sudo reboot
      When the unit boots it will display the IP address it is set to.
