Errors after restart
    When I restart HS3 everything seems to look fine, but then I get errors in the log when my Kinect detects motion.
    Plug-in is running remotely.
    I've included some of the log file below.
    What should I do to resolve?
    Feb-13 9:38:35 PM Startup Settings Loaded.
    Feb-13 9:38:35 PM Startup ************************************************************ ********************
    Feb-13 9:38:35 PM Startup HomeSeer version 3.0.0.152 Edition: HS3 Pro Starting Now
    Feb-13 9:38:35 PM Startup Creating Class Objects...
    Feb-13 9:38:35 PM Startup COM port classes started.
    Feb-13 9:38:35 PM Startup Application interface class started.
    Feb-13 9:38:35 PM Startup Web server class started.
    Feb-13 9:38:35 PM Startup E-Mail SEND class started.
    Feb-13 9:38:35 PM Startup E-Mail RECEIVE class started.
    Feb-13 9:38:36 PM Startup Plug-In Interface class started.
    Feb-13 9:38:36 PM Startup HSPhone external interface class started.
    Feb-13 9:38:36 PM Startup Local voice recognition class started.
    Feb-13 9:38:36 PM Startup Database SAVE process started.
    Feb-13 9:38:36 PM Startup Loading configuration file ...
    Feb-13 9:38:36 PM Database Opening (Mode=Read Only) up HomeSeer database C:\Program Files\HomeSeer HS3\Data\HomeSeerData.hsd
    Feb-13 9:38:37 PM Database Loading Devices...
    Feb-13 9:38:37 PM Load Config 83 total devices loaded.
    Feb-13 9:38:37 PM Load Config Loading Event Groups...
    Feb-13 9:38:37 PM Load Config Loading Events...
    Feb-13 9:38:37 PM Load Config 4 total events loaded.
    Feb-13 9:38:37 PM Load Config Loading COUNTERS...
    Feb-13 9:38:37 PM Load Config Loading TIMERS...
    Feb-13 9:38:37 PM Startup HomeSeer version is: 3.0.0.152
    Feb-13 9:38:37 PM Startup Creating Speaker Client Interface Object...
    Feb-13 9:38:37 PM Startup This version of HomeSeer is registered as a HS3PRO version.
    Feb-13 9:38:37 PM Info Remote plug-in API interface started on port 10400
    Feb-13 9:38:37 PM Startup Checking for available plug-ins
    Feb-13 9:38:38 PM Plug-In Found plug-in: BLBackup, version: 2.0.14.0
    Feb-13 9:38:38 PM Plug-In Found plug-in: BLRfid, version: 2.0.7.0
    Feb-13 9:38:38 PM Plug-In Found plug-in: HSTouch Server, version: 3.0.0.59
    Feb-13 9:38:38 PM Plug-In Found plug-in: Kinect, version: 3.0.0.20
    Feb-13 9:38:38 PM Plug-In Found plug-in: NetCAM, version: 3.0.0.11
    Feb-13 9:38:38 PM Plug-In Found plug-in: RCSStat, version: 3.0.0.12
    Feb-13 9:38:39 PM Plug-In Found plug-in: X10, version: 3.0.0.35
    Feb-13 9:38:39 PM Startup Initializing Plug-Ins
    Feb-13 9:38:39 PM Info Plugin BLBackup has connected. IP:127.0.0.1:49206
    Feb-13 9:38:39 PM BLBackup start Initializing BLBackup...
    Feb-13 9:38:39 PM BLBackup start BLBackup version is: 2.0.14.0
    Feb-13 9:38:39 PM BLBackup start Loaded configuration successfully
    Feb-13 9:38:39 PM BLBackup start Backup Folders have been loaded.
    Feb-13 9:38:39 PM BLBackup start BLBackup plugin has been initialized
    Feb-13 9:38:39 PM Plug-In Finished initializing plug-in BLBackup
    Feb-13 9:38:40 PM Info Plugin Kinect with instance E5410 has connected. IP:127.0.0.1:49212
    Feb-13 9:38:41 PM Kinect DEBUG Logger Initialized
    Feb-13 9:38:41 PM Kinect INFO Kinect version 3.0.0.20
    Feb-13 9:38:41 PM Kinect DEBUG Voice Recognition Initialized
    Feb-13 9:38:41 PM Kinect DEBUG Drawing Zones File
    Feb-13 9:38:41 PM Kinect DEBUG Deleting image file Kinect/zones_E5410/zones0.jpg
    Feb-13 9:38:41 PM Kinect DEBUG Writing image file Kinect/zones_E5410/zones1.jpg
    Feb-13 9:38:41 PM Kinect DEBUG Visual Recognition Initialized
    Feb-13 9:38:41 PM Kinect DEBUG Web Pages Registered
    Feb-13 9:38:41 PM Kinect WARNING No Kinect found
    Feb-13 9:38:41 PM Kinect DEBUG End Init
    Feb-13 9:38:42 PM Plug-In Finished initializing plug-in Kinect
    Feb-13 9:38:43 PM Web Server Local IP address (subnet) is: 192.168.1.7 (255.255.255.0)
    Feb-13 9:38:43 PM Web Server Web Server started on port 810
    Feb-13 9:38:43 PM Startup Creating ASP.NET application host...
    Feb-13 9:38:46 PM Startup Start automation engine...
    Feb-13 9:38:46 PM Startup Initializing Speaker Client Interface
    Feb-13 9:38:46 PM Speech Listening for remote speaker connections on port 10401
    Feb-13 9:38:46 PM Startup HSSentry is disabled in Setup, sentry will not be started.
    Feb-13 9:38:46 PM Database Opening (Mode=Read/Write) up HomeSeer Energy database C:\Program Files\HomeSeer HS3\Data\Energy\Energy.hsd
    Feb-13 9:38:46 PM Startup Updater services starting...
    Feb-13 9:38:46 PM Startup Starting DDNS service...
    Feb-13 9:38:47 PM Startup Running the startup script Startup.vb
    Feb-13 9:38:52 PM Startup Starting Event Scheduler...
    Feb-13 9:38:52 PM Startup (Startup.vb script) Scripting is OK and is now running Startup.vb
    Feb-13 9:38:52 PM Startup (Startup.vb script) No speaker clients detected, waiting up to 30 seconds for any to connect...
    Feb-13 9:38:52 PM Startup HSSentry is disabled in Setup, sentry will not be started.
    Feb-13 9:38:52 PM Startup Start up complete.
    Feb-13 9:41:11 PM Info Plugin Kinect with instance E5410 has connected. IP:192.168.1.22:50690
    Feb-13 9:41:12 PM Kinect DEBUG Logger Initialized
    Feb-13 9:41:12 PM Kinect INFO Kinect version 3.0.0.20
    Feb-13 9:41:12 PM Kinect DEBUG USB\VID_045E&PID_02C2\6&114CB089&0&1 status=Connected
    Feb-13 9:41:12 PM Kinect DEBUG Voice Recognition Initialized
    Feb-13 9:41:13 PM Kinect DEBUG Drawing Zones File
    Feb-13 9:41:13 PM Kinect DEBUG Deleting image file Kinect/zones_E5410/zones0.jpg
    Feb-13 9:41:13 PM Kinect DEBUG Writing image file Kinect/zones_E5410/zones1.jpg
    Feb-13 9:41:13 PM Kinect DEBUG Visual Recognition Initialized
    Feb-13 9:41:13 PM Warning Attempt by plugin to register a duplicate link of kinectconfig. Plugin: Kinect Instance: E5410
    Feb-13 9:41:13 PM Kinect DEBUG Web Pages Registered
    Feb-13 9:41:13 PM Kinect INFO Kinect initialized
    Feb-13 9:41:13 PM Kinect DEBUG End Init
    Feb-13 9:41:13 PM Kinect DEBUG Building Grammars
    Feb-13 10:15:00 PM Log Maintenance 6 records, selected by date/time, were removed from the log database.
    Feb-13 10:15:00 PM Log Info The log database is currently 0.71MB in size.
    2/14/2015
    Feb-14 1:15:00 AM Log Maintenance 4 records, selected by date/time, were removed from the log database.
    Feb-14 1:15:00 AM Log Info The log database is currently 0.71MB in size.
    Feb-14 2:36:10 AM Kinect ERROR Object reference not set to an instance of an object.
    Feb-14 2:36:10 AM Kinect INFO Frame skipped
    Feb-14 2:36:11 AM Kinect DEBUG at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IHSApplication.SetDeviceValueByRef(Int32 dvRef, Double Valuenum, Boolean trigger) at HSPI_KINECT.Zone.set_SkeletonCount(Int32 value) at HSPI_KINECT.VisualRecognition.kinectRuntime_SkeletonFrameRea dy(Object sender, SkeletonFrameReadyEventArgs e)
    Feb-14 2:36:11 AM Kinect INFO Frame skipped
    Feb-14 2:36:11 AM Kinect ERROR Object reference not set to an instance of an object.
    your logs show that 2 instances of the plugin with the same name are running:
    you can't have 2 instances running with the same name, if you only have one kinect running remotely you don't have to start the local instance, so disable it from the "PLUG-INS > Manage" page and leave it like this.
    not sure if this is the cause of the errors though...
      There is only one instance running. It is remote. The plug-in is and has been disabled on the HS3 computer.
      There is only one ini file with the E5410 designation.
      What do you suggest to eradicate the phantom instance?
        hmm, are you sure?
        in the manage page in the Enable column, you shouldn't see any green buttons for the kinect plugin, even for the E5410 instance.
        on the HS3 computer, in task manager, do you see a HSPI_Kinect.exe process?
          That's probably it. I thought I needed to add an instance on the manage page for the remote instance.
          Added:
          Disabling the remote instance was all it took. Thanks. I'm slowly learning how the system works.
            Is this license error related to my previous mistake? The remote instance seems to be working.
            What do I need to do to resolve it?
            Edit: Never mind. I found the answer in another thread. Just have to wait for it to resolve itself.
            _
              _
              I will try to have Rich have a look at this problem, but as other users reported this doesn't seem to prevent the plugin from working.
              If you delete the second line on your screenshot, the one that says "loaded remotely" then restart everything (HS3 and remote instance), do you have the same problem? (you don't have to manually create the E5410 instance for the remote instance to work)
                Unfortunately, no. The only change is that the deleted line is gone. The remote plug-in appears to be connecting and functioning properly, though.
