Changed port on ISY - what do I need on plugin
    Current Date/Time: 9/19/2017 11:58:29 AM
    HomeSeer Version: HS3 Pro Edition 3.0.0.357
    Operating System: Microsoft Windows Embedded Standard - Work Station
    System Uptime: 1 Day 1 Hour 22 Minutes 15 Seconds
    IP Address: 192.168.1.8
    Number of Devices: 109
    Number of Events: 9
    Available Threads: 200
    Enabled Plug-Ins
    3.0.0.47: ISYInsteon
    3.0.1.130: Z-Wave
    I needed to change the port on my ISY.
    Now it appears the plugin cannot communicate with ISY. What do I need to do to re-establish connectivity?
    Jim
    You need the COM port that it changed to.
    Look in 'Device Manager' in the 'Control Panel' of Windows.
    Look under COM devices
    You can compare to what COM device is currently setup in the plugin.
      Under the plug-in configuration update the ISYT IP/Host field to include the port:
      I.E. something like 192.168.1.x:5000
      Bob Paauwe
      ISYInsteon Plug-in
        Bob,
        Adding the port did the trick - Thanks!
