Zipato Bulb 2
    Zipato Bulb 2
    Hi All,
    Anyone know if the Z-Flash is compatible with the Zipato Bulb 2?
    I recently purchased one and have no blue channel. They apparently need to upload a new HEX file but I don't have a Zipato controller. They suggested I asked about z-flash as they were unsure if it was compatible.
    OK, sorted it with help from Matt @ Homeseer.
    For the benefit of anyone else who may run into this...
    Z-Flash is compatible. I ran into issues where Z-Flash could not negotiate security protocols with the bulb. After lots of back and forth with a few tech's, we finally found a workaround. You need to remove the device from your Homeseer, and re-add as unsecure. It'll then let you flash it.
      Thank you
