Web page builder for Homeseer 3 & Homeseer 4
    #76
    Originally posted by drozwood90 View Post
    late to the game, but has anyone proved that this does / does not work with a HS Zee?
    --Dan
    No, the Zee does not support .asp. Although ASPX pages are technically supported, they don't work...taking several minutes to render or more likely timing out.
    Jon
      #77
      Originally posted by Rotech View Post
      Got it Jon....!!! Is there a way to eliminate the text next to the icon? See pic above with circle.
      Any thoughts about this?
      Hector
      Win.2003 OS, HS3
      MyTrigger,ACRF2,W800,Zwave
      AP800,Honeywell Stat
        #78
        You will need to post the few lines from the ini file that you have used to configure that section of the page.
        Jon
          #79
          Originally posted by MFULLER View Post
          Thanks Jon00. I'm going to try and make a class and apply to just one sub heading. I want all the right sub headings to be right aligned.
          Made two pages so far.. One for my iPhone and one for the ipad. Looking good so far.. Love this plugin
          Ipad ones are almost finished, but a couple more things to add and alignments to sort out
          Marc, nice on/off buttons. Do you mind sharing the CSS you are using for the buttons?
          Billy
            #80
            these are the lines for the Lamp Ligth pictured above. as you can see next to the icon theres text (showing "on" or "off") how can that be removed, since the icon already informs the status?
            Also I need to change the color of the text on the button to black. Since I am using rtubutton light button, you can bearly see the text. I am still struggling to understand the concept, but Ill get there.
            Column1Section1-10Height=
            Column1Section1-10Left=Lamp Ligth
            Column1Section1-10Middle=[device,003D0A7A-031]   [button,On,EventRefresh1,,rtubutton light,40]  [button,Off,EventRefresh2,,rtubutton light,40]
            Column1Section1-10Right=[devicelastchange,"Jon00-NOAA-10"]
            Column1Section1-11Left=Power Room Ligth
            Column1Section1-11Middle=[device,003D0A7A-027]
            Column1Section1-11Right=[devicelastchange,"Jon00-NOAA-10"]
            Hector
            Win.2003 OS, HS3
              #81
              Baby steps....
              Change the part:
              to:
              [deviceimage,003D0A7A-031
              Does that remove the text for you?
              Please remember that this package was primarily designed to display information...it does have basic control functionality but is not a replacement for HSTouch.
              Jon
                #82
                Baby steps....
                Change the part:
                to:
                Thank you Jon, that did work!!! Now, the text color is lite for the button background. I need to change it to black. Again thk u for your help.
                Hector
                Win.2003 OS, HS3
                  #83
                  Hector,
                  The button styles that come with the package are configured in a file called buildpagebutton.css
                  This is located in your html\css folder.
                  You can modify it to change the text color, however it will affect all buttons in that style.
                  To do so, open up buildpagebutton.css in a text editor.
                  Search for a line that looks exactly like this:
                  .rtubutton {
                  Then scroll down the page until you find:
                  color: #fff;
                  Change this line to:
                  color: #000;
                  Now save.
                  Refresh the page and the button text should be black.
                  Jon
                    #84
                    So I need to add a period before "ligth" (rutbutton.ligth)?
                    Hector
                    Win.2003 OS, HS3
                      #85
                      No, my mistake on that one.
                      Jon
                        #86
                        Hey guys, anybody noticing that if you try to activate a button in my case for a ligth ( in my ipad) that it sometimes works and sometime it doesnt? When I press the button I notice that it refreshes, but sometime won't turn on the ligth and other attempts the ligth turns on, but the device icon doesn't change.
                        Hector
                        Win.2003 OS, HS3
                          #87
                          Well this is still un finised, here what I done so far. I need to know if the sub header can be a continues bar (circled). I tried all possible option, but gets me no where.
                          Hector
                          Win.2003 OS, HS3
                            #88
                            Hey Hector. I am not familiar with the word "Ligth" is this "Light" in another language. Just curious. Thanks.
                              #89
                              Quick typing and bad spelling lol Thks.
                              Hector
                              Win.2003 OS, HS3
                                #90
                                Quick answer...No.
                                Jon
