Fail on startup migrating to HS3
    Plug-in worked great in HS2, migrating to HS3 on same WinXP machine and now get the following: (log is in reverse chron order)
    Jan-04 10:51:11 AM Plug-In Finished initializing plug-in BLNetCallerId
    Jan-04 10:51:11 AM BLNetCallerId Error DatabaseFunctionsSingleton.CompactDatabase(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLNetCallerId\BLNetCallerId.mdb
    Jan-04 10:51:11 AM BLNetCallerId Error DatabaseFunctionsSingleton.CompactDatabase(): An error has occurred during compacting of the database: Retrieving the COM class factory for component with CLSID {CD7791B9-43FD-42C5-AE42-8DD2811F0419} failed due to the following error: 80040154 Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG)).
    Jan-04 10:51:11 AM BLNetCallerId start BLNetCallerId plugin has been initialized
    Jan-04 10:51:11 AM BLNetCallerId Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): sqlUpdateString: DELETE from tblCallLog WHERE txtDateTime < #1/4/2014 10:51:10#
    Jan-04 10:51:11 AM BLNetCallerId Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): DatabasePathAndName: C:\Program Files\HomeSeer HS3\Data\BLNetCallerId\BLNetCallerId.mdb
    Jan-04 10:51:11 AM BLNetCallerId Error DatabaseFunctionsSingleton.PerformDatabaseUpdate(): An error has occurred during database update statement: ExecuteNonQuery requires an open and available Connection. The connection's current state is closed.
    Jan-04 10:51:11 AM BLNetCallerId Error DatabaseFunctionsSingleton.GetADODBConnection(): Caught exception opening database connection: The 'Microsoft.ACE.OLEDB.12.0' provider is not registered on the local machine.
    Jan-04 10:51:10 AM BLNetCallerId start Phone Line 1 (COM5) is Open!
    Jan-04 10:51:10 AM BLNetCallerId start Loaded configuration successfully
    Jan-04 10:51:10 AM BLNetCallerId start BLNetCallerId version is: 2.0.18.0
    Jan-04 10:51:10 AM BLNetCallerId start Initializing BLNetCallerId...
    Jan-04 10:51:10 AM Info Plugin BLNetCallerId has connected. IP:127.0.0.1:1329
    Any thoughts?
    Thanks in advance,
    Rob in Maine
    See this post:
    http://forums.homeseer.com/showthread.php?t=160399
      Thank you Rupp! Immediately fixed the issue.
      Have a prosperous New Year.
      Rob in Maine
