Hello,
I am running jessie on a rapberry pi 3 and have installed the HS3 raspberry IO plugin on it. The homeseer server "sees" it as a remote plugin. However, it says "No license or Trial Expired". I purchased the license, and the register button for enabling it on the REMOTE plugin won't take it. "doesn't match product". Even though the plugin says "OK" and gives the proper IP address of the remote Pi. However, it does work to license on the raspberry pi that is the homeseer server. I have that disabled as I am not using the IO port on the server, just the remote Pi. I cannot configure devices on the remote pi due to the license issue (I suspect). I am also getting the message "System is not a Raspberry Pi" on the remote pi. I am running HS3 3.0.0.297 and Pi plugin version 3.0.0.5. How can I enable the licensing on the remote Pi now that I have purchased it for $29.95?
David
David
