Originally posted by macromark
View Post
First Alert ZCOMBO-G
Originally posted by TechFan View PostI can easily create the alert. . .I guess I just want to make sure I change the batteries when they need to be. . .I don't care if I hear the chirping. I would like to know that the alerts are actually catching a low battery state (or that is what the chirping really means). I guess what I am wondering is if the ZSmoke ZWave scale isn't out of 100. . .so we should have 70ish as the bottom of the battery scale. . .?
Techfan what was the time period from when you put the battery in to the first chirp sound(78% battery level?)
Would love to put like 5 of these in my house, but if they start chirping at different battery levels and at 78% battery level( if this is true) these smokes wouldn't stay up for long.
Originally posted by TechFan View PostThe chirping just lets the non HS admin occupant know that it is time to change the batteries. I guess that is unfortunate. . .and one reason ZWave devices haven't flown much in the non-tech household. . .I can't imagine considering that type of inconsistent battery level acceptable.Tom
Ive got the buyin from wife on these so i too am curious...battery chirping at 25% would be acce0table but 78%?
Ill buy rechareables then
Sent from my Samsung Galaxy Note 3HW - i5 4570T @2.9ghz runs @11w | 8gb ram | 128gb ssd OS - Win10 x64
Seems there are a lot more smartthings and vera users using these or so the google search finds.
From reading a few of their post it seems, these unit start chirping when the battery falls below 80%.
from the ST forum:
"I've had my detectors for several months, and the only time they've chirped was to alert me on low battery, typically anything below 80%. The only thing they report in the event log is battery level, and don't test themselves unless the button is pushed. If yours are chirping, check your battery level."
So how many months does it take to get a fresh set of batteries to 80%?Tom
I have had mine for about two years. . .I don't think I have changed batteries more then 3 times at the most. . .so they last plenty well. . .but the battery scale isn't accurate. I haven't ever recorded when I changed my batteries, so I need to start doing that to keep track.
It seems that the reported status could be adjusted by customizing the graphic level pairs, but I haven't tried that. I have wondered if there is any documentation that specifies that the battery levels are supposed to work differently than the 0-100 scale.
Hello,
Hope someone can help me with this importing this device in HS2. Reading this post it should not be an issue using the Z-troller serial. I have firmware version 1.17. It is adding the device to the Z-troller but when I try to import it I get.
Found node 48. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 48, cannot continue to load this node.
Any suggestions?
Marcel
First Alert Z Combo
Added Z Combo with no problem but unable to send e-mail upon triggering Alarm Test event with either my att.net account (error log says possible SSL problem) or with GMAIL...I get the following message from Google when I try to use it...Someone just tried to sign in to your Google Account xxx from an app that doesn't meet modern security standards.
Thoughts?
Bob
Originally posted by bobpak View PostAdded Z Combo with no problem but unable to send e-mail upon triggering Alarm Test event with either my att.net account (error log says possible SSL problem) or with GMAIL...I get the following message from Google when I try to use it...Someone just tried to sign in to your Google Account xxx from an app that doesn't meet modern security standards.
Thoughts?
Bob
Cheers
AlHS 4.2.8.0: 2134 Devices 1252 Events
Any suggestions?
Marcel
Error: The device Node 8 Z-Wave Sigma Sensor Alarm Node 8 is not a normally listening node, and an attempt to communicate with it has failed. To use the functions on this page, please make sure the device is awake and ready to receive a command prior to selecting the function buttons below.
Any idea on how to best handle?HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostWhen I imported my devices from my Z-troller, I get a device named Sigma Sensor Alarm Node 8. Going into the properties of the device and try to rescan I get the following despite me hitting the test button.
Any idea on how to best handle?cheeryfool
I was wondering about this. However, I also run HS2 with these on the same box. So I'm slowly migrating and when I've had enough fun, I again bring back my HS2. If I do as you suggested, I wonder how this impacts HS2 since the Z-troller already knows about these devices ...HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
