This plugin is designed to interface HomeSeer with the Autelis Pool Control systems. It is compatible with Pentair Intellitouch or EasyTouch controllers, Pentair SunTouch controllers, Pentair Intelliflo controllers, Jandy/Zodiac controllers and Hayward/Goldline controllers
Please read the User Guide before installing.
Installation:
- Added support for Pentair Intelliflo
Changes to v3.0.0.22
- Added "Reboot Autelis Controller" action
Changes to v3.0.0.21
- Fixed multi instance feature
- Added "control use" for Heat device
Changes to v3.0.0.20
- Added possibility to customize request timeout from ini file
- Set "Chlorination error" device to "GeneralFault" if data cannot be retrieved.
Changes to v3.0.0.19
- Fixed error handling and polling timer
Changes to v3.0.0.18
- Added pumps information for Pentair and Jandy controllers.
Changes to v3.0.0.17
- Added support for chemistry information for Jandy controllers
Changes to v3.0.0.16
- Added a dropdown list for setpoint devices
- Create AUX devices for Jandy even if names.xml is not available
Changes to v3.0.0.15
- Added "Solar Temperature" device for Pentair systems
Changes to v3.0.0.14
- Fixed Off control for Janddy Lights.
Changes to v3.0.0.13
- Fixed Pentair chlorinator error messages
Changes to v3.0.0.12
- Added support for Jandy lights and AUX names
Changes to v3.0.0.11
- Fixed parsing of chlorerr field
Changes to v3.0.0.10
- Fixed chlorinator controls
Changes to v3.0.0.9
- Added support for chemistry for Pentair controllers
Changes to v3.0.0.8
- Added "Poll For Status" event action
Changes to v3.0.0.7
- Added support for Hayward/GoldLine controllers
Changes to v3.0.0.6:
- Added support for Jandy/Zodiac controllers
Installation:
- download the zip attached to this post and save it in the HS3 application folder in /updates3/zips
- download the file named updater_override.txt attached to this post and save it in the HS3 application folder.
- go to the "PLUG-INS > Manage" page and click the "Update Listing" button, then click "Additional interfaces > Test Plugin" and check the Autelis Pool Control line.
- click the "Download and Install" button
- enable the plugin from the "PLUG-INS > Manage" page
- delete updater_override.txt from your HS3 application folder
Changes to v3.0.0.9
Changes to v3.0.0.8
Changes to v3.0.0.7
