Video guide:
https://youtu.be/l2oCQk7qdZM
Version: HomeSeer 3 running on Linux.
The code entered into speak.sh is (all on one line):
curl -v -H "Accept: application/json" -H "Content-type: application/json" -X POST -d ' {"communication_base_params":{"type":"Message","fallback":fa lse,"via":"GCM"},"sender":"HomeSeer Speaker","ttl":0,"message":"'"speaker =:= $1"'" ,"version":"1.63"} ' http://192.168.0.109:1817
You need to change the IP address to the IP of your Android phone, in the above case my Android devices IP address is 192.168.0.109
If you want your local HomeSeer speaker client to continue working, do not make any other changes to speak.sh other than pasting the above code at the bottom of the file and changing the IP address. My speak.sh is already customised all you need to do is paste the above code down the bottom after changing the IP.
This guide is complex, I am not responsible if you break your setup. You should have knowledge of Linux and Tasker before attempting to set this up. This is not an official HomeSeer Guide.
Video of some of the cool things I have done using Tasker, Autovoice, Autoremote, Autowear and the HomeSeer JSON interface:
https://youtu.be/SD9-vzY15yQ
