I am missing something on the install... The squeezecenter side went OK but when I extract the Homeseer files to D:\program files (default location on a Hometroller) aand stop and restart Homeseer, I don't get anything in the Interfaces tab. Did I extract to the wrong location?
New SqueezeBox Plug-in
Originally posted by johnoc View PostHomeseer 2 has been the folder name on my machine for years.... It most likely depends on what flavor of HS you are running...
I don't know enough about Homeseer to know if non-Hometroller versions use a different directory name but that is what I was guessing after seeing what the plugin created. I also don't know how plugins work or where the files for them usually reside but it seems like a manual copy from the Homeseer 2 directory that was created to the same locations in the Homeseer HS2 directory should accomplish what the plugin installation directions were aiming for.
Very excited about this plugin!
Will it work with V7.0 of SC, installed on a Linux machine with HS installed on another machine. (HS is on my Hometroller 2 and SqueezeCenter is on my Thecus N5200 Pro)? I'm waiting for 7.3 to be released, which is when a non-beta version of the N5200 build is due to be released, which is why I'm still on V7
EDIT: Just read the instructions and see that i need SC7.2+, guess I'll have to wait or upgrade earlier tan plannedJohn
Hardware: i5-6400T w/16GB RAM & SSD w/HS3Pro, Z-Net, Harmony Hub x2, Echo Dot x2, Ocelot
Plugins: Z-wave, HSTouch, BLBackup, Harmony, GTS CPUXA, UltraMon3, Nest
HSTouch: Multiple Android Devices; 5 x ToteVision MD-1001 10.1" Win 7 Tablets
Devices: Cooper RF9501 x4, RF9517 x6, RF9534 x1, RF9540-N x7, RF9542 x1, RF9542-Z x2, RFHDSCG x1, RFWC5 x5; Intermatic HA02 x6; FortrezZ MIMOLite x3; Leviton VRPD3-1LW x4, VRR15-1LZ x6; Nest Tstat & 9x Protects; Dragon PD-100 x3, PA-100 x3
I am making progress but not quite there yet. I have the plugin installed and I see all 17 of my music players on the plugin stautus page but only 12 of them got created as devices in Homeseer. How do I get the plugin to create devices for the rest of the players? Do I disable and then re-enable the plugin? Do I delete all the devices and somehow tell the plugin to create everything over again?... Not sure what to try next.
Edit - I tried deleting all the devices and restarting Homeseer. I still only get 12 players. The highest device number is $64... don't housecodes go up to 99?Last edited by upstatemike; December 11, 2008, 09:58 PM.
Originally posted by upstatemike View PostThe plugin created a "Homeseer 2" directory structure that looks similiar to what I see in the "Homeseer HS2" directory that Homeseer runs from. Should I manually copy files from "Homeseer 2" to the same location in "Homeseer HS2" ?
Originally posted by apluck View PostPlay playlist with ui would be ideal!
I tried the send message action, but it doesnt let you set the duration, and it doesnt scroll line 1 and line 2 if they don't fit on the screen, hence trying the script option.
Thanks for the script sample, I'll try that later.
Originally posted by upstatemike View PostI am making progress but not quite there yet. I have the plugin installed and I see all 17 of my music players on the plugin stautus page but only 12 of them got created as devices in Homeseer. How do I get the plugin to create devices for the rest of the players? Do I disable and then re-enable the plugin? Do I delete all the devices and somehow tell the plugin to create everything over again?... Not sure what to try next.
Originally posted by pcp View PostOops my doing. I somehow set the maximum devices to 64 instead of 99. I will fix that in the next version (most likely via updater).
SqueezeCenter Plugin is GREAT!
I tried the plugin with SC 7.0 and could not get the config screen to load, so it's a no-go with SC 7.0, at least the N5200 build.
I wanted the functionality this plugin adds so badly, that I bit the bullet and upgraded to SC 7.3. It was a little painful, but well worth it.
My main reason for wanting the plugin was to be able to controll my Duet Receiver with a standard IR controller. I now can with a few simple events, power on/off, play, pause, stop, skip, next and previous song with the same remote I control the volume of my receiver with. This is Awesome!!! I love the Duet controller, but sometimes it's just easier to use the IR remote, especially once a desired playlist is loaded and all I want to do is skip around without loading a specific song. Reponse is great, just as quick as using the Duet Controller (which makes sense, since the controller and plugin take to SqueezeCenter the same way - over IP).
I've tested it extensively and it worked flawlessly all weekend. GREAT JOB!
Now on to the feature requests:
1. Event action to change shuffle mode on selected player (this way I can select among shuffle settings). This would be best as a discrete selection for each shuffle type (none, album, song?) so that I won't have to guesse the current shuffle mode.
2. Another device to show the thumbnail of the current playing selection, and possibly another device to show a larger version of the artwork. These, along with the other device strings and various event actions would be great for making custom interfaces in HSTouch, MainLobby or any of the other front-end applications (Though, I think Cinemar needs to come up with their own, full-featured SquezeCenter Plugin/interface as an option for MusicLobby instead of JRMC...)
Again, thanks for the great job, I consider this an early Christmas present!John
Originally posted by jrfuda View PostI tried the plugin with SC 7.0 and could not get the config screen to load, so it's a no-go with SC 7.0, at least the N5200 build.
