As a sign of support I made my purchase for the plug in today. It has been rock solid and I can reach out with a cat 5 cable to control devices or gather information. POE (power over Ethernet) can make it all just one single wire to that location. Thanx.
It would be nice to gather ideas as to how others are using the analog features of the arduino to interface with HS3. Using changing values to make decisions and what next action needs to be done to change the value back to the "ideal" value by way of a fan, opening a window, moving something and on and on.
I'm having trouble using the analog values and I'm sure others might be too HS3 has not provided any information as to how to manipulate these values into useful actions my first attempt was with the ADIO100, it sits aside now that I have the Arduino. Is there more information about using the API? Perhaps someone can provide an example from conception to working. I know I'm going to learn to use the sketches to use the possessing features in the Arduino to perform actions and send back the results to HS3 so I can use other technology's connected to HS3 to turn lights on, send an email, connect to another Arduino on the other side of the house, property or city and take readings of temperature or current being drawn from a battery or solar charger.
Has anyone thoughts on being able to record the analog values or digital I/O's into a chart or data base to use in a way to measure progress on the signals HS3 is using to make decisions to help "tune" things up. It would be very helpful to capture the data to adjust the way HS3 is seeing things to get what is desired.
Thanx again for a very promising introduction to a very flexible device that anyone can now access no matter their programming abilities.
