Is anyone else having an issue getting the plugin to work
    #46
    Originally posted by Blade View Post
    You are seeing this with the latest in the updater?
    Yes, with .27 I have the issue. Just to prove I hadn't gone mad I went back to .19 and here is works fine.
    Nicolai L
      #47
      Can you try 2.0.28 in the updater and let me know
      If you have an issue can you capture a debug log of the issue and attach zipped
      Cheers,
      Bob
        #48
        Yup, .28 has issues too for me. It is weird because quite often the command goes through correctly, but roughly 1 in 5 fails and the amp goes to "Min" but the GUI shows the level it was trying to set.
        Debug attached.
        Nicolai L
          #49
          Try 2.0.29 and let me know if any better
          if issues then capture a debug log of just the volume issue that sets it back to min
          Cheers,
          Bob
            #50
            Thanks - Initial feedback would suggest this has fixed the issue for me. I'll do some more testing and revert if I find I still have issues.
            Nicolai L
              #51
              heres some more info..
              I am trying to get to basics..
              Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
                #52
                .29 !!!!! working w/ NR-626 ! ( volume settings for main solid ! )
                Zone 2 also "looks" solid -- nothing hooked up right now
                  #53
                  Question..
                  2nd receiver, has a seperate address, does it need to run on an alternate port id: 60130 or stay on 60128 ?
                    #54
                    60128 should work
                    Cheers,
                    Bob
                      #55
                      grrr.. lost access to my other receiver
                        #56
                        got some feedback back but still no control keeping hopes up most features worked b4
                          #57
                          Blade is still hard at work....
                            #58
                            @ blade if need be you can teamveiw into my setup and play around as long as u dont crank volume have 3000 watts pumping subs lol
                              #59
                              What model are you using?
                              Is it the same as gearyt?
                              Cheers,
                              Bob
                                #60
                                same here.... welcome to come take a gander
