I have attempted to get the Run Times chart report working again in this build.
You will need to install the SQLite ODBC driver on your HS3 machine in order for this to work
Here is the link for the driver:
http://www.ch-werner.de/sqliteodbc/
Once you are on the web site, I downloaded the sqliteodbc.exe link and installed it on my HS3 machine and it seems to work fine.
After you have installed the sqliteodbc driver then do the following:
1. Update BLStat to the latest in the HS3 updater
2. You need to make sure that the System.Data.SQLite.dll file in your [HS3 root]\Bin\BLStat is the same file size as the one in [HS3 root]\html\bin (the file size should be 246Kb)
3. If they are not the same copy the one from [HS3 root]\Bin\BLStat to [HS3 root]\html\bin and overwrite it (you may have to shutdown HS3 in order to do it)
