Error at start up and shut down
    For the last few restarts I have been getting the following error at startup. Running the beta .402
    1/17/2018 10:26:32 AM ~!~PHLocation Error~!~(CreateDeviceLists) Error with Dv: 1127 - System.NullReferenceException: Object reference not set to an instance of an object. at q.r()
    Also - When you shut down HS3, all the plugins shut down except PHLocation. I have always received the error in windows it would not shut down with the following:
    Problem signature:
    Problem Event Name: CLR20r3
    Problem Signature 01: HSPI_PHLocation.exe
    Problem Signature 02: 3.0.1.109
    Problem Signature 03: 59df1004
    Problem Signature 04: System
    Problem Signature 05: 4.7.2558.0
    Problem Signature 06: 59d41488
    Problem Signature 07: 8ae
    Problem Signature 08: 6d
    Problem Signature 09: System.Net.HttpListenerException
    OS Version: 6.3.9600.2.0.0.272.7
    Locale ID: 1033
    Additional Information 1: 5861
    Additional Information 2: 5861822e1919d7c014bbb064c64908b2
    Additional Information 3: d2dd
    Additional Information 4: d2ddcae25462e2b2f29684f70c88f75a
    Let me know if I need to capture anything else.
    Found the solution. Somehow a new Phone was started but never configured. It was not in the plugin but was in the device database. Once I removed them from the database and restarted HS3, the missing device error was gone.
    Second - the Shutdown error. Each time I shut down HS3, PHLocation would continue to run. There was an issue with the exe accessing an IP outside of the network and the firewall was stopping it. I have it set so if a program changes and is trying to contact an IP outside of my network, I need to approve it the first time and then it run without issue until it changes again. Once I checked the IP and approved the change, the startup and shuddown of the exe continued without issue.
    Michael
    HS3Pro & HS4Pro on Win2012R2
    Aeotec, Cooper, Cree, GE/Jasco, Intermatic, LIFX, Fortrezz, OSRAM, RCS, Trane, Zooz
    BLBackup, BLGData, BLRussound, BLSpeech, HSTouch, InvisaLink, HSBuddy, IFTTT, JowiHue, NetCAM, PHLocation, Pushover 3P, Random, rnbWeather, UltraLighting3, weatherXML, ZigBee, Z-Wave
    Problem signature:
    Locale ID: 1033
    Michael
    I installed 3.0.0.402 when Rich announced it this morning. I have restarted HS several times for testing and am not getting PHLocation errors. PHLocation is also working properly. I am not sure if it is a device, but do you have a PHLocation device with a RefID of 1127?
      I cannot find a device of 1127. I looked when I saw the error. I have had the shut down issue for a while now. It is the only plugin that will not shut down when HS3 does. I get the windows box to shut it down.
      M
