I'd like to be able to control volum via infraref using a Duet Combo. Currently, I can control both power, input and volume of one of my AV receivers that is connected to my SqueezeBox 3 using the IR plugin for that device (a non-HS related plugin). It works great. It allows me to leave my SB3 at a fixed volume (via its setting) but still have it pass on volume commands recieved via it's IR remote or via the SqueezeCenter interface (or, idirectly via the HS plugin!).
I'd like this replicated with the Duet, using the HS plugin as an intermediate. All it would require is a trigger based on increase or decrese of the duet receiver's volume (actually, based on a command from a controller or squeezecenter to increase/decrease the Duet Receiver's volume, since it will be fixed via setting). This trigger can then be used to send an IR command via HomeSeer.
I'd use this to control the volume of my Zone 2 amplifier. When I'm outside, my Duet Controller can penetrate the walls to relay commands, but my IR remotes cannot. This would be an awesome feature!
Thanks again!
Thanks again!
