are pH Sensor readings possible
    Hi Spud,
    I wanted to build a raspberry pi to read the pH of a pool...And then noticed your plug-in.
    The vendor of the pH probe has sample code to make it work with a pi, can your plug-in read the pH values?
    Sample link
    http://atlas-scientific.com/_files/c...ample_code.pdf
    I can buy one and help you build it if you want?
    Thanks for everything
    Chris
    Originally posted by clafa View Post
    Hi Spud,
    Sample link
    Chris
    What sensor are you using to get the pH readings?
    Sent from my Xoom using Tapatalk
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      Hi Spud,
      Sample link
      Chris
      The plug-in only support digital inputs or outputs, so it won't work with this pH probe.
      I have no plan to add support for i2c right now, sorry.
