Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > mcsSprinklers
Old March 21st, 2018, 10:45 PM
slocanlarry slocanlarry is offline
2 Rain8net Master Controllers
In the interview process there is a page that asks for the number of Master Controllers - perfect! When I select 2 (presumably so that I can specify 2 COM ports on a later page) it will not accept it - the page just refreshes with the query box empty. Can't seem to get past this to actually enter the Port numbers for each master.
Current Date/Time: 3/21/2018 7:39:54 PM
Operating System: Microsoft Windows 10 Home - Work Station
System Uptime: 0 Days 0 Hours 49 Minutes 56 Seconds
IP Address: 192.168.1.111
Number of Devices: 537
Number of Events: 233
Available Threads: 800
Enabled Plug-Ins
3.0.0.29: ADIO-100
2.0.49.0: BLBackup
2.0.35.0: BLSecurity
1.0.3.0: BLShutdown
2.0.22.0: BLUPS
3.0.6.3: Insteon Thermostat
3.0.6.23: Insteon
2.18.0.4: MCSSPRINKLERSP
Old March 22nd, 2018, 12:46 AM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is online now
The interview may have an issue in this area as not many use multiple masters. Go the Other Page and at the bottom select Expert Mode. Go to the Rain8/Devices Page and then do the entry of the second port. You can go back to User mode after this if you like.
Old March 24th, 2018, 06:50 PM
Ok this worked to open two ports. Still struggling. Can't seem to set it up to recognize even one valve from each Rain8net master box. Even though the plug-in recognizes that I have two masters (COM11, COM12) that are set up to be #1 and #2 as per instructions, there is no communication and I'm getting errors in the Homeseer log file:
Mar-24 3:19:47 PM mcsSprinklers ReadSprinklerZones valve NET:2:1 does not exist in Unit dictionary
Mar-24 3:19:47 PM mcsSprinklers ReadSprinklerZones valve NET:1:1 does not exist in Unit dictionary
Mar-24 3:19:37 PM mcsSprinklers OpenProgrammingPort Line 0 The port 'COM' does not exist.
Mar-24 3:19:36 PM mcsSprinklers ReadSprinklerZones valve NET:2:1 does not exist in Unit dictionary
Mar-24 3:19:36 PM mcsSprinklers ReadSprinklerZones valve NET:1:1 does not exist in Unit dictionary
how should I proceed?
Old March 24th, 2018, 07:35 PM
post your file that is at HS install location /Config/mcsSprinklers.ini. I can then see what you have setup and provide specific guidance.
Old March 25th, 2018, 11:31 PM
zipped ini file attached - thanks
Old March 26th, 2018, 08:47 PM
I loaded your file and see the two Rain8Net units setup, but the Wiring page does not have the candidate valves for use. I need to look into what has happened. Likely related to the interview with dual units not being done correctly. It should not be hard to get over this hurdle and then it should be clear sailing.
Old March 26th, 2018, 10:47 PM
I did the following steps. You should be able to use the attached .ini to continue
Other Page
Homeseer Setup Options selected R and S for Valve and Status house codes.
This appears to be the root cause of problems. HS no longer makes these manditory.
I should have this as part of interview. It should have defaulted to R and S, but did not see it.
Rain8 Page
Did Save to assure the two Rain8 units were setup
Wiring Page
1 wire in harness #1. I changed it to 8 to handle all your potential wires from first module. Did Save
This made all the valves available for selection.
I selected first one and set control valve 1 from unit 1 to be control for "Front Drip"
Did Save
Second wiring harness becomes available. I selected 8 number of wires for it too.
Did Save.
I selected first row in second harnesse and set control from valve 8 unit 2 to be control for "Back Lawn"
I selected second row and assigned Valve 1 Unit 2 to ""Veg Garden"
Did Save
At this point there are three valves assigned across your two Rain8 modules
Layout Page
Clicked Area 1 to be Front Drip
Clicked Area 2 for both Veg Garden and Back Lawn
Did Save
Selected Dront Drip Auto and Manual minutes to 40
Selected Veg Garden to 15 minutes for both
sELECTED 30 minutes for Back Lawn
Did Save
Area Page
Area 1 Control Strategy for Interval every 3 days
Area 2 Control Strategy to be ET (calculated) with moisture level at 20%
Area 2 Inhibit time to Absolute 00:00 (midnight) to From Sunrise -01:00 (1 hour before sunrise)
Weather Setup
Noticed WeatherUnderground selected for current conditions and None for forecast, but a license was entered.
Assuming you want to manage irrigation with weather both the Weather Source and Forecast Source need to be setup.
The location given for Forecast is not a valid one. It needs to be one recognized by the Forecast source.
NWS does not need license. UW and Accuweather need free license.
Same for WeatherUnderground as Weather Source.
I selected NWS just to have something, but did not do anyting for current conditions.
Did Save
Clicked the Evaluate Internet Download from Selected Stations and page showed the date, but no readings.
This could be because forecast from NWS is not valid after 6 PM.
Zone Status
Clicked Activate For Season button
General Status
Clicked Front Drip ON button. Observed the sprinkler icon starts turning.
Clicked General Status link and see R19 icon is red to indicate fail.
Clicked Seriod IO link. See no serial ports open (dont have 11 & 12 on my computer)
Clicked Run Log llink. See one line with Rain8 Fron Drip ON
Clicked Other link. At bottom under Debug Data files, clicked Produce Debug Data Files.
These will be needed to support until you become comfortable with operation.
Did Save
Zipped up file for you as a starting point to continue.
Old March 28th, 2018, 10:51 AM
thanks. will try this and see where it gets me. much appreciated.
Old March 28th, 2018, 11:50 PM
Success - both Masters operating on independent COM ports. Bench tested relays OK. Now to figure out all the other options you have to offer.
Thanks again for your help - and quick responses. Two thumbs up!
Old March 28th, 2018, 11:53 PM
Glad you have success. Sorry that there were issues initially.
Do rain8net controllers work? ChrisO Irrigation Discussion 16 August 22nd, 2012 06:37 AM
Rain8net WGL 41014 Pro2 master with Input Feature TomTom HmeSeer RainRelay8 Plug-in 1 July 27th, 2012 09:22 AM
New user installing Rain8Net with Master Valve rayhurst mcsSprinklers 1 June 5th, 2009 07:45 PM
Getting a master hub - how do I use it? cadillackid xAP Discussions 16 February 21st, 2008 01:18 AM
Master.js dlgardne Script & Plug-In Library Discussion 5 January 24th, 2004 09:14 PM
