Hello Bruce,
Just a quick question for you. I was checking my log and the largest activity is the following message: bobcat humidity unit 2 has been set to xx
and gts cpuxa variables variable 10 has been set to xx. It appears to be updating every second? Consequently most of the activity in the log is from the bobcat humidity sensor. Is there a way to change this and if so what is a reasonable recommended polling value? Thanks much !!!! Rick
