Although it is physically not possible to have 2 TV programs started at identical times for a single station, the xmltv files I download in the Netherlands, contain sometimes such records.
The hstv.exe program cannot handle such and aborts complaining that it can not store records with identical (index)keys. Which is correct: in the access database (in the temp table) I found one record too many.
Also I found that one of these double records (the one that is too many, which should be ignored) have identical start and endtimes. When those records are deleted or ignored in the Access database everything seems to be working correctly!
I was wondering if someone (CFGuy?) could update HSTV.exe so it will ignore (during the import fase, not the download!) records which have identical start and stoptimes?
Henk
Henk
