Go Back   HomeSeer Message Board > HomeSeer Products & Services > HomeSeer Help > How-To's
How-To's This area provides in-depth information on how to do something in HomeSeer or home automation.
Old March 12th, 2018, 08:44 PM
Pete's Avatar
Pete Pete is offline
OverSeer
DIY a combo ZWave and Zigbee controller
This will be a sort of ZNet like device except for using Zigbee and ZWave.
I do not use wireless or bluetooth on my RPi's today so may go with a Rock64 to be able to run Ubuntu 16.04 64 bit.
- RPi2-3 with case and power supply
or
- Rock64 2Gb with case and power supply - found out the Rock64 will fit in an RPi case with a little mod to the power piece - making it a little larger.
You access all the connectors including sdcard, audio, lan and usb with a regular pi case.
Note these are the same price today.
- ZWave GPIO card
- Zigbee GPIO card
- POE power splitter
RPi OS
- Stretch
or
Rock64 OS
- Ubuntu 16.04 64 bit
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
Old March 12th, 2018, 08:45 PM
Pete's Avatar
OverSeer
Saved.
Pete's Avatar
OverSeer
Saved...
Old March 12th, 2018, 09:01 PM
reidfo's Avatar
reidfo reidfo is offline
Seer Master
Sounds like an interesting project, Pete. I have been looking a little into ZigBee lately, and also possibly a custom RF receiver using an SDR module. I have a Pi3 already transmitting sensor data from my ePool sensor (pH, Temp, ORP), so it would be easy to add more interfaces.
HS Pro 3.0 | Linux Ubuntu 16.04 x64 virtualized under Proxmox (KVM)
Hardware: Z-NET - W800 Serial - Digi PortServer TS/8 and TS/16 serial to Ethernet - Insteon PLM - RFXCOM - X10 Wireless
Plugins: HSTouch iOS and Android, RFXCOM, BlueIris, BLLock, BLDSC, BLRF, Insteon PLM (MNSandler), Device History, Ecobee, BLRing, Kodi, UltraWeatherWU3
Second home: Zee S2 with Z-Wave, CT101 Z-Wave Thermostat, Aeotec Z-Wave microswitches, HSM200 occupancy sensor, Ecolink Z-Wave door sensors, STI Driveway Monitor interfaced to Zee S2 GPIO pins.
Old March 12th, 2018, 09:26 PM
Pete's Avatar
OverSeer
Yes here the POE RPi in the attic is connected to a GPIO ZWave card, 1-wire 9097 and an SDR radio for NOAA maps and node red and MQTT stuff. Purchased a second SDR radio module to test some more and currently testing this one in my home office while concurrently just built a new RPi for the basement 1-wire stuff (well it'll go to the main floor and outside).
This DIY would be keeping it simple with the Zigbee and ZWave interface and now that you have written about it an SDR add.
Thinking folks on the Domoticz site are already doing this (except that most of the plugins are written in Lua running on the RPi).
How are you doing the sensor data with the outdoor Pi3?
HTML code is On
DIY Zigbee controller Pete How-To's 3 February 26th, 2018 06:21 AM
Zigbee and zwave what's the difference? Rotech HomeSeer General Discussion Area 15 July 14th, 2016 02:22 PM
RPi based controller for zigbee rmasonjr HomeSeer General Discussion Area 1 November 20th, 2015 03:51 PM
Is zigbee and zwave the same? Rotech HomeSeer Z-Wave Plug-in 8 May 11th, 2014 02:07 PM
Conference info on ZigBee and 802.11n and ZWave Stevech General Home Automation Hardware Discussion 0 July 20th, 2006 11:52 PM
