Go Back   HomeSeer Message Board > 3rd Party Plug-Ins/Scripts > Plug-ins by Author > Click Here for List of Author Forums > MCS Plug-Ins and Scripts > mcsMQTT (3P)
mcsMQTT (3P) Discussion of mcsMQTT plug-in
  #301
Old Today, 01:51 PM
Pete's Avatar
Pete Pete is offline
OverSeer
@Michael,
Curious about the picture in the mcsMQTT plugin manual showing Garage Door manual parameters configuration page showing relay pulse and maximum time for input change where as mine only shows top half of parameters.
Automator
HS3 Pro & Lite Edition Beta 3.0.0.435
  #302
Old Today, 02:57 PM
Michael McSharry's Avatar
Michael McSharry Michael McSharry is offline
OverSeer
The Garage Door was my first Tasmota mod and there was some "hard coded" logic that worked for me, but was later changed to make it more generalized. The GPIO were selected to be 09 and 10 Switch1 and Switch2. With mcsTasmota there are 56 and 57 for Door Open and Door Closed sensors. If you select these then then relay and max time settings on the browser should be available. I dont remember what testing I did again for Door control after I added these. If you have an issue I can look back at it with one of my extra Sonoff's. I dont want to mess with my Sonoff that is working well in the garage now. There is also firmware_door.bin (December) and firmware_door_counter.bin (March) and firmware_hue.bin (May) which are images I captured as each project was done. The mcsTasmota added irrigation scheduling.
  #303
Old Today, 03:13 PM
Pete's Avatar
OverSeer
Thank you Michael.
Automator
HTML code is Off
ERRO Calling SetIOMulti in plugin Arduino Plugin:Object reference not set to an in fvhemert Arduino Plugin (3P) 5 April 28th, 2017 10:15 AM
Nest Plugin Errors - cannot change temperature via plugin TimSRQ Nest Devices (3P) 2 August 15th, 2016 08:48 AM
Upgrade procedure for ACRF plugin from W800 free plugin htsource ACRF Processor (3P) 14 January 26th, 2006 11:21 AM
Switch-to messages, plugin restart, and plugin startup Michael McSharry Plug-In Development 4 January 27th, 2003 11:20 PM
