I want to turn off a dimmer switch after it has been on for exactly 5 minutes.
You used to be able to specify a RANGE of values (1...255) but now you can't.
I know I can create a timer and then write several events to turn the timer on, off, and trigger the OFF when the timer hits 5 minutes. But that's a lot of work and I want to do this action on a number of dimmers so if there is a way to do this without timers that would be great.
I've read http://board.homeseer.com/showthread.php?t=172750 but it doesn't go thru this level of detail.
The screen shot show what I want to do. The current event work ONLY if the dimmer is fully ON which is not the case 99% of the time. I can only specify a single dim level. I supposed I could enter 99 OR statements for each dim level.
Seems like a pretty basic thing everyone would want to do - am I missing something???
