OMNI Plugin v3.0.2.8
    #46
    Originally posted by jchotz View Post
    I updated to V28 and it did not fix the 2 problems that I have.
    1 - my UPB devices that control fans & flour lites still do not turn on. They did previous to V26 and now they do not. I think this has to do with ramping them. Can you please put this back so that my lites & fans work again?
    2 - still does not find any zones on my exp enc. What can I tell/show you that would help you diagnose why it continues to miss the EE zones?
    Thx, Jeff.
    Roll back to the prior version until I can come up with a fix that addresses Dim/Brighten/Level
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      #47
      i am guessing i would of had to of backup prior to upgrade in order to roll back. or is there a place to download older version of the plugin
        #48
        You would need to restore it from a backup.
          #49
          I have .28 and the previous version .26 also had that behavior. How to roll back to the version prior to .26 please?
            #50
            The easiest way would be to restore from your backup. All you would need is the HSPI_OMNI.exe
              #51
              Could you post that file here in a zip for us?
              <style></style>
                #52
                Here is one from November 2017. Looking at it in Linux I cannot tell which version it is.
                  #53
                  Yeah, I'm a doofus w/o a backup so I'll just have to wait for the fix. <sigh> Lesson learnt.
                    #54
                    For a quickie backup of HomeSeer just:
                    1 - shut the HomeSeer application via Homeseer 3 GUI
                    2 - install WinSCP on your Wintel computer
                    3 - connect to your HomeSeer box via WinSCP
                    4 - copy the /usr/local/HomeSeer directory to say a USB stick or some place you will remember
                    5 - unzip the file above and using WinSCP write the file to the /usr/local/HomeSeer directory and it will replace current Omni Plugin.
                    6 - ssh to your box and type sudo reboot
                      #55
                      Anyone figure out what version "the file above" is?
                      <style></style>
                        #56
                        <style></style>
                        I'm assuming it's the one three posts above yours...
                          #57
                          All Pete says is "Here is one from November 2017. Looking at it in Linux I cannot tell which version it is. "
                          That doesn't identify which specific file version it is. V.24, V.25, V.27, etc
                          <style></style>
                            #58
                            <style></style>
                            Gotcha.
                              #59
                              Here is V.24 and V.25
                              and
                                #60
                                I cannot find my Omni V.26 or V.27 updates because none of the zip files when updating are being saved anymore in the most current builds of Homeseer 3.
                                I only backed up the Homeseer directory when upgrading versions of Homeseer.
                                Checking old Omni updater txt files update downloads the old dropbox links / files do not exist anymore from November-December 2017.
