I am having problems with my Z wave network, which had been running for years in a stable fashion. For a yearHS 2 2.5.0 .23
Ztrollar on Windows 7 ultimate.
about a week ago when HomeSeer boots many of the devices show the black bar with red question mark "unknown". I can manually control them. Once I click them on or off the "unknown" disappears at the appropriate icon shows up.
I have rebooted a number of times. I removed the batteries in the Z-troller briefly while it was totally disconnected to reboot it.
Under Setup/Interfaces/Manage the results of the testing is pretty much the same;.
Full synchronization states that each of the nodes "cannot be reached" or "failed to get basic node information." It also reports about "new" nodes 27, 29, 30, which do not exist.
I do own Z-Seer. It indicates it will not do reports remotely. Although it is running on the local host.
It shows zero good packets and one bad packets for each node. Both commands and responses. Optimization does not correct this. It does say all nodes are good neighbors
Any tips appreciated. Thank you in advance Kevin
Loading network information from your Z-Wave interface... Done.
Synchronizing network information against HomeSeer devices...
The Z-Wave network has 21 nodes.
Device Z-Wave Kevins Room Ceiling Light already exists for node 2. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Ceiling Light at node 2 could not be reached - no updates to the device information available.
Device Z-Wave Upstairs Hall Light already exists for node 3. Syncing node information with the HomeSeer device.
Device Z-Wave Upstairs Hall Light at node 3 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Bedside Lamp already exists for node 4. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Bedside Lamp at node 4 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Sheet fed scanner already exists for node 5. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Sheet fed scanner at node 5 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Printer/Flat Bed Scanner already exists for node 6. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Printer/Flat Bed Scanner at node 6 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Coffee Pot already exists for node 7. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Coffee Pot at node 7 could not be reached - no updates to the device information available.
Device Z-Wave Basement Server already exists for node 8. Syncing node information with the HomeSeer device.
Device Z-Wave Basement Server at node 8 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Sound Mixer already exists for node 9. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Sound Mixer at node 9 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Right Monitor already exists for node 11. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Right Monitor at node 11 could not be reached - no updates to the device information available.
Device Z-Wave Kevins Room Left Monitor already exists for node 12. Syncing node information with the HomeSeer device.
Device Z-Wave Kevins Room Left Monitor at node 12 could not be reached - no updates to the device information available.
Found node 19. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 19, cannot continue to load this node.
Device Upstairs Kevins Room Z-Wave Thermostat 20 already exists for node 20. Syncing node information with the HomeSeer device.
Device Upstairs Kevins Room Z-Wave Thermostat 20 at node 20 could not be reached - no updates to the device information available.
Device Ground Floor Front Living Room Media Center Computer already exists for node 21. Syncing node information with the HomeSeer device.
Device Ground Floor Front Living Room Media Center Computer at node 21 could not be reached - no updates to the device information available.
Found node 22. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 22, cannot continue to load this node.
Found node 23. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 23, cannot continue to load this node.
Device Upstairs Kevins Room Drone Two already exists for node 24. Syncing node information with the HomeSeer device.
Device Upstairs Kevins Room Drone Two at node 24 could not be reached - no updates to the device information available.
Device Z-Wave Z-Wave Interface Z-Wave Dimmer Switch already exists for node 25. Syncing node information with the HomeSeer device.
Device Z-Wave Z-Wave Interface Z-Wave Dimmer Switch at node 25 could not be reached - no updates to the device information available.
Device Z-Wave Z-Wave Interface Z-Wave Dimmer Switch already exists for node 26. Syncing node information with the HomeSeer device.
Device Z-Wave Z-Wave Interface Z-Wave Dimmer Switch at node 26 could not be reached - no updates to the device information available.
Found node 27. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 27, cannot continue to load this node.
Found node 29. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 29, cannot continue to load this node.
Found node 30. Retrieving class and manufacturer information from the node.
Failed to get basic node information from new node 30, cannot continue to load this node.
Instructing the Z-Wave thermostat functions in HomeSeer to verify all Z-Wave thermostats.
Finished with Z-Wave device synchronization.
