X10 newb
Originally posted by kideon View PostSo I found a ds10a while moving and decided to finally play around with it. Running the latest beta of the plugin on an Insteon hub v1. How I make it work?
Did go through the documentation still am lost since this doesn’t have switches to set the code or anything. I made the device in homeseer hit all the options it shows Insteon x10 in the advanced tab. Updated x10 in the plugin. Just lost.
these devices don't send traditional x10 mgs.
you need a plugin like the rfxcom and antenna to receive these signals and convert them to x10
i think there is an rf to x10 antenna wall unit you could use.Last edited by mnsandler; October 27, 2017, 05:34 PM. Reason: i think there is an rf to x10 antenna wall unit you could use.Mark
HS3 Pro 4.2.19.5
Here continue to utilize the old X10 Palm pads and other X10 wireless input devices like the CM11A et al. The batteries on these devices last forever.
For the garage stuff here use one X10 Palm pad which will trigger off the repetitive speech when the garage door is open, trigger multiple UPB light switches (for daylight in garage), temperature, et al. Use another X10 Palm pad to test irrigation zones manually.
I personally like mixing my Homeseer stuff here and continue to utilize X10 (and UPB, ZWave and Zigbee). Using the OmniPro panel I do proprietary wireless to solenoid switches which connect to the panel for other stuff.- Pete
