I've got an i2 TriggerLinc open/close sensor that recently stopped reporting. While in linking mode and doing a comm test, it scores 100% every time. When I open/close the door, the LED lights up and a nearby power line only dimmer module's LED flickers to show Insteon activity, yet no report to HS. I've ran "Program Device for Homeseer", and checked for bad links. I've restarted the plugin, then HS. I thought this might be related to my other recent communication problems on another circuit, but with 100% ping and zero updates it seems something else is wrong. I've also been deleting old, unused links in other devices recently but unsure how that could be related either.
This device is considered in a lot of events and scripts so before I do something stupid that requires a new device ID, is there anything else I can try to get this working again? If I factory reset the device and do a "Reprogram Device", will that give me a new ID?
