I've been porting my HS2 to HS3 and have been trying to re-write some of the events to work properly.
At the moment I'm trying to change an ISY state variable value from the HS3 plugin.
If I try to use the ISY ISYInsteon Device Actions I get an error message that says 'Error calling the plug-in to get the Action UI: An entry with the same key already exists'. So that choice is out.
I tried using the standard device-action with the variable as a homeseer device but there's no way to change the value. I thought maybe the devicestring got passed as text but that doesn't seem to be the case.
Any help would be appreciated.
mark
mark
