I have some questions on how the Arduino API 'holds' or sends Input values to Homeseer.
It seems that the Input 'retains' an old value and when Arduino sends the new value they get "added" or something...see below.
Scenario:
I am reading the pH value and when I use the 'standard' sketch the sensor reads the correct value. I know its the correct value since I have standard pH Buffer solutions that I use to test (4,7 and 10 pH).
pH =4 (buffer solution) reads 4.1
However when I use the HS3Arduino API sketch I get very different results.
pH = 4 (buffer solution) reads 17.83 when read from the Homeseer Device.
Same sensor, same buffer solution (didn't change anything, just the sketch)
I even tried sending the pH sensor value in mV to see if it read the same but somehow even this gets changed when reading it in the Homeseer Device.
Standard sketch
mV = 2560
HS3Arduino APi
mV = 2319
I am attaching the standard sketch and the HS3Arduino sketch I am using and the HS3 devices showing the results.
NOTE HS3 Device Values
Board 1, Output 0 (I just use to send data to Homeseer)
Board 1, Input 1 (pH)
Board 1, Input 4 (mV)
Any feedback is appreciated.
Scenario:
Standard sketch
mV = 2560
HS3Arduino APi
mV = 2319
