I have 2 questions,
1.
In the docs there is....
Update: (This has the following options)
Value. (Select this to update the device value with the value you send from the board.)
String. (Select this to update the device String with the value you send from the board.)
Value & String. (Select this to update the device value and String with the value you send from the
board.)
The comments in the api sketch show a example with SendToHS(api device, value). There is no example for a string.
I would like to update the value and string. How do I send both the value and string back to HS?
2.
Again in the docs, there is....
In your code To Send Data to Homeseer use SendToHS(Device,Value) you can send a int, Long or Float to Homeseer.
Is the data type automatically figured out by the plugin? How do I configure a device to a long or float max value?
I don't have a need for anything bigger than an integer, but I would like to understand how to do it.
1.
board.)
2.
