Z-net devices required
    I sthere a recommendation as to how many z-net devices one should have, and specifically, how many devices they would be realistically expected to control with minimal latency.
    Also, is there any interference between devices on the z-wave side (I plan to use a wired interface for the network side)
    The limit on total devices per controller is 232. I had a single Z-Net with 114 devices with no latency. I have since split my network to 3 Z-Nets, all different HomeIDs, currently with 91, 16 and 14 devices respectively. There is no perceptible speed difference between the small and large networks.
    I did not split the network because of speed issues, only so that devices in outbuildings could communicate directly with their controller. I had a bunch of Jasco devices that only support pseudo instant status when communicating without hops.
    While this does not directly answer your question, it does seem to show that a large number of devices has no impact on speed.
      The computational power of a Z-Net so far exceeds what's needed you will never see a bottleneck at the controller. If you think about it most Z-Wave controllers are tiny USB things. The Z-Net has more computational power than most home automation "hubs" all together with their Z-Wave controller and associated computational needs.
      Originally posted by rprade
        Thanks, I was thinking more about the turn on our off of am devices - such as when leaving the home. If however there is no perceivable delay, it would make my setup easier to have a single z-net in my computer room with a ups.
        Is there any experience in terms of indoor transmission up 2 floors. (wood construction).
        I once had a 900 MHz phone, and could talk with the base station downstairs from up stairs.
          With a Z-Net you will have absolutely not coverage issues.
