Aeotec Home Energy Meter ZW095
I just installed one of these a few weeks ago. It is currently working in my setup. I will post some screen shots when I get home.
Just an FYI, the directions are not real clear, at least the screens shots that I saw were somewhat inconsistent. For the clamps, could you make out the K->L lettering? The L stands for load and make sure you put the clamps on the way power is flowing concerning the arrow. I could barely see the indicators on my clamps, so I took a black magic marker and ran it over them. The symbols are more visible out now.
Once the unit was installed I did a light optimize several times, then a full and the unit worked well.
Do you have this user guide, see https://aeotec.freshdesk.com/support...en5-user-guide-Billy
Aeotech Home ENergy Meter Settings
bdraper,
Excellent support the picture was worth the 1000 words.... This was the step I was missing
Clicked on the root device
Clicked on "Audit This Node" tab ;;;; I've never used this screen before.
I now have everything showing data
I appreciate your assistance
Devoir
I am starting with ZW095 and thanks to the forum I got it set up and it seems to be working.
I don't understand how I should treat readings from two clamps - AMP and WATTS values a slightly different. Should I just use data from one clamp and disregard the second. Or, should I calculate average for each reading?
As an example, I turned on a small burner of my stove for a few seconds and here is what I got in the log.
I don't understand the power consumption - does the burner use around 450 Watts or does it use 904 Watts (450 + 454)?
Hope that someone can clear it for me, thank you.
1 Photo
Here is an attempt to explain(I don't have this unit so I am somewhat guessing at setup):
I assume you have basically a 240 Volt "Feed" coming into your home and a Neutral . The Voltage from one "Feed" to Neutral is 120 Volts and 120 Volts from the other "Feed" to Neutral. These two I assume are Volts1 and Volts2 in your Z-wave device. For most of your home(lights and outlets) they are wired to one phase or the other and are 120Volts. Something like an electric stove or air conditioners are wire directly to the 2 Feeds and run on 240 Volts. The total power, watts, used in your home is the sum of the power used in the two "Feeds" or the sum of the 2 Feed currents times 120 Volts or the sum of Watts1 and Watts2 as you were surmising. Hope I haven't confused!
Thank you, it makes sense to me - each clump does its job independently and total usage should be a sum of two readings.
My next thought on this was - if stove takes about equal amount of energy from each phase, why do I need to use clamps on both wires. Why wouldn't I just use one clamp for only one wire/phase and then double the KWh reading in a script? This would free up another clamp that I could use for measuring current on a completely different breaker.
I wonder if this would be electrically/magnetically possible to separate clamps like this... or they absolutely have to be connected to one load/both phases....
Thanks again
Is your Aeotec an older one or is it a gen5. I have an older one, Gen1 or 2 I think. It works ok for awhile but then stops, which sounds the same as yours. I was thinking they may have improved it over the years and I was thinking of buying a new one. If yours is a Gen5 then this would be a waste of money. I worked with Aeotec a few years ago but no progress was made. I like it when it works but it fails so many times I am thinking of ditching it for another brand.
Originally posted by bearben25 View Post
Did you ever get this working? I'm having similar issue on HS4.
For Homeseer there are a few settings that you'll need to change to allow this device to work properly on Homeseer HS3:
Pair HEM Gen5 V1.35 using non-secure
1. Unpair HEM Gen5
2. Re-pair HEM Gen5 using "Non-secure" pairing via Homeseer interface (don't use regular pairing)
Changing Parameter settgs
1. Access the root of the HEM Gen5
2. Go to Z-Wave tab -> Settings.
3. Input these parameter settings individually at the bottom:
Parameter 2 [1 byte] = 0 //disable solar
Parameter 3 [1 byte] = 0 //disable threshold
Parameter 13 [1 byte] = 1 //enable CRC16 encapsulation (Homeseer requires this)
Parameter 101 [4 byte] = 1776384 //report all reports on clamp 1 + 2 via group #1
Parameter 111 [4 bytte] = 30 //Set the time of report for group #1
4. Save this.
5. If you are still now getting any readings, move onto the association section below:
Association (steps for is your HEM Gen5 is still not reporting)
2. Go to Z-Wave tab -> Association.
3. Click on "Update" button
4. Click on "X" on Node #1 under "Group 1"
5. Now click on "Update" button again.
6. Input this into
"Device to be Controlled" -HomeSeer
"Destination Endpoint" -(No Endpoint)
7. Now click on "Add Association"
Let me know if this works for you, based on my previous tests, this has worked for most.
- Likes 2
