Changing SetPoints
    Changing SetPoints
    Hi All,
    It been a while since I've looked at this but is there a way of changing the setpoints other then from the plugin's configuration page?
    I'm want to create events which update the setpoints and also change them from within HSTouch on my phone/tablet for example.
    The Devices created by the plugin only seem to let you view the current temperature/humidity and not adjust the setpoint
    All the Best
    Dean
    Let me check on this and get back to you. I recently disconnected my temp/humidity sensors and I need to get them back online to test.
    I'll respond to this thread when I find out.
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      Hi Rob, Did you have any joy? shout if there is anything I can do my end.
      Deano
        Hi Deano - I found that the setpoints can only be changed through the plugin page. I can add the same functionality to HS events, but it will take a little while. I will add it to the list, but it may be a while before I can get to it.
          Hi Rob, Did this ever get added?
          Deano
            No, right now, the setpoints can only be changed via the plugin page.
