the following zwave messages have been flooding my log, does anyone have an idea why? Thanks
Dec-15 6:39:00 PM Z-Wave Set_New_Level_Real called for Thermostats Living Room Liv Rm Temp, Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
Dec-15 6:39:00 PM Z-Wave Set_New_Level_Real: Initial device is Thermostats Living Room Liv Rm Temp
Dec-15 6:39:00 PM Z-Wave Set_New_Level_Real: STARTING
Dec-15 6:38:12 PM Z-Wave Set_New_Level EXITING
Dec-15 6:38:12 PM Z-Wave Set_New_Level FINISHING(L) COMMAND_CLASS_SENSOR_MULTILEVEL_V7
Dec-15 6:38:12 PM Z-Wave Device: Thermostats Basement Base Temperature Set to 69 (F)
Dec-15 6:38:12 PM Z-Wave Set_New_Level, Parent: Thermostats Basement Base Thermostat Node 2 Root, Child:Thermostats Basement Base Temperature
Dec-15 6:38:12 PM Z-Wave Set_New_Level_Real called for Thermostats Basement Base Temperature , Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
Dec-15 6:38:12 PM Z-Wave Set_New_Level_Real: Initial device is Thermostats Basement Base Temperature
Dec-15 6:38:12 PM Z-Wave Set_New_Level_Real: STARTING
Dec-15 6:34:49 PM Z-Wave Set_New_Level EXITING
Dec-15 6:34:49 PM Z-Wave Set_New_Level FINISHING(B) COMMAND_CLASS_THERMOSTAT_OPERATING_STATE_V2
Dec-15 6:34:49 PM Z-Wave Set_New_Level, Parent: Thermostats Basement Base Thermostat Node 2 Root, Child:Thermostats Basement Base Operating State
Dec-15 6:34:49 PM Z-Wave Set_New_Level_Real called for Thermostats Basement Base Operating State, Type=COMMAND_CLASS_THERMOSTAT_OPERATING_STATE_V2, EndPoint=0
Dec-15 6:34:49 PM Z-Wave Set_New_Level_Real: Initial device is Thermostats Basement Base Operating State
Dec-15 6:34:49 PM Z-Wave Set_New_Level_Real: STARTING
Dec-15 6:31:59 PM Z-Wave Set_New_Level EXITING
Dec-15 6:31:59 PM Z-Wave Set_New_Level FINISHING(L) COMMAND_CLASS_SENSOR_MULTILEVEL_V7
Dec-15 6:31:59 PM Z-Wave Set_New_Level, Parent: Thermostats Living Room Liv Rm Thermostat Root, Child:Thermostats Living Room Liv Rm Temp
Dec-15 6:31:59 PM Z-Wave Set_New_Level_Real called for Thermostats Living Room Liv Rm Temp, Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
Dec-15 6:31:59 PM Z-Wave Set_New_Level_Real: Initial device is Thermostats Living Room Liv Rm Temp
Dec-15 6:31:59 PM Z-Wave Set_New_Level_Real: STARTING
Dec-15 6:31:50 PM Z-Wave Set_New_Level EXITING
Dec-15 6:31:50 PM Z-Wave Set_New_Level FINISHING(B) COMMAND_CLASS_THERMOSTAT_OPERATING_STATE_V2
Dec-15 6:31:50 PM Z-Wave Set_New_Level, Parent: Thermostats Kitchen Kitchen Thermostat Node 8 Root, Child:Thermostats Kitchen Kitchen Operating State
Dec-15 6:31:50 PM Z-Wave Set_New_Level_Real called for Thermostats Kitchen Kitchen Operating State, Type=COMMAND_CLASS_THERMOSTAT_OPERATING_STATE_V2, EndPoint=0
Dec-15 6:31:50 PM Z-Wave Set_New_Level_Real: Initial device is Thermostats Kitchen Kitchen Operating State
Dec-15 6:31:50 PM Z-Wave Set_New_Level_Real: STARTING
Dec-15 6:27:37 PM Z-Wave Set_New_Level EXITING
Dec-15 6:27:37 PM Z-Wave Set_New_Level FINISHING(L) COMMAND_CLASS_SENSOR_MULTILEVEL_V7
Dec-15 6:27:37 PM Z-Wave Set_New_Level, Parent: Thermostats Basement Base Thermostat Node 2 Root, Child:Thermostats Basement Base Temperature
Dec-15 6:27:37 PM Z-Wave Set_New_Level_Real called for Thermostats Basement Base Temperature , Type=COMMAND_CLASS_SENSOR_MULTILEVEL_V7, EndPoint=-1
Dec-15 6:27:37 PM Z-Wave Set_New_Level_Real: Initial device is Thermostats Basement Base Temperature
Dec-15 6:27:37 PM Z-Wave Set_New_Level_Real: STARTING
Dec-15 6:26:49 PM Z-Wave Set_New_Level EXITING
Dec-15 6:26:49 PM Z-Wave Set_New_Level FINISHING(B) COMMAND_CLASS_THERMOSTAT_OPERATING_STATE_V2
Dec-15 6:26:49 PM Z-Wave Set_New_Level, Parent: Thermostats Basement Base Thermostat Node 2 Root, Child:Thermostats Basement Base Operating State
Dec-15 6:26:49 PM Z-Wave Set_New_Level_Real called for Thermostats Basement Base Operating State, Type=COMMAND_CLASS_THERMOSTAT_OPERATING_STATE_V2, EndPoint=0
