I happened to notice the CPU usage of my HS box was over 50% and holding steady, which is quite unusual. It's usually well below 10% and oscillates up and down with a fairly regular pattern.
When I investigated further I discovered that it had risen suddenly at about 5:03 this morning. No other measures changed, and HS did not appear to be doing anything special when the jump occurred. (We and the house were in asleep mode.) Here's the HS CPU usage (in %):
9/25/2012 4:48:36 AM 3.98
9/25/2012 4:50:37 AM 4.15
9/25/2012 4:52:42 AM 3.60
9/25/2012 4:54:47 AM 3.65
9/25/2012 4:56:52 AM 5.09
9/25/2012 4:58:57 AM 3.59
9/25/2012 5:01:05 AM 5.16
9/25/2012 5:03:30 AM 51.63
9/25/2012 5:05:46 AM 51.00
9/25/2012 5:07:36 AM 52.41
9/25/2012 5:09:49 AM 51.22
9/25/2012 5:11:59 AM 52.47
9/25/2012 5:13:51 AM 50.56
9/25/2012 5:16:31 AM 51.37
9/25/2012 5:18:13 AM 52.58
When I attempted to restart HS it hung and I had to force it closed with Task Manager. When I restarted it it was clearly not behaving normally and triggered it's own restart routine. That also failed to get it running properly, and it restarted on its own again. After the third restart it seemed to be back to normal and appears to be running normally since.
Any ideas would be appreciated.
