Open/Close for blinds
    recently got my alexas working with homeseer, i cant seem to get my blinds to do open/close, i have to use on off. am i missing something or is this a feature?
    thanks
    Raptor
    HS3 Pro on Windows 8 64bit
    53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
    Check out my electronics blog here:
    https://www.facebook.com/RaptorsIrrationalInventions
    Are you using the HS Skill or the Connected Home API? The former is "Alexa, tell HomeSeer..." For the latter: https://forums.homeseer.com/showpost...72&postcount=4
    HS4Pro on a Raspberry Pi4
    HSTouch Clients: 1 Android
      thanks, i am using the Alexa API as i find it more fluid than "tell homeseer to"
      i just tested it and it works with on off but not open close... very odd.
      this is how my device is setup
        Seeing same issue... any news or thoughts of what to try?
        Andrew B.
          That is a limitation of using the Smarthome skill. You can only use on/off commands.
          Try the Homeseer skill.
            You can use more than just on/off. Check the link above.
              Thanks for the info. Did not realize they updated that.
                Thanks for the pointer, thats good info
                HS 2.2.0.11
                  OK I'm a little confused. I used these details and option 1..
                  http://homeseer.com/amazon-echo-integration.html
                  Where is the Alexa API ? I'd like to use additional commands rather than just on/off....or am I using it ???
                  Thankyou..Pete
                  HS 2.2.0.11
                    OK well I can confirm the "open" command doesnt work with all devices...
                    "Alexa open front gate" works most times
                    "Alexa open front door" just wont work. I do Simon says and it heard me fine. I was wondering if it was an issue with the word door, tried simply changing it to garage and same result.
                    "Alexa run front door" works fine.
                    Havent found a pattern of behaviour yet to see what the issue is...
                    Pete
                    HS 2.2.0.11
