BLDSC now supports Envisalink
This is a sticky topic.
    I finally received my Envisalink 4 and have updated BLDSC to use the Envisalink
    Make sure you are running 2.0.38 or later
    Cheers,
    Bob
    Is there any additional functionality supported by using the Envisalink
      I don't think so but have not fully played with it yet
      It allows you to not have to use a serial port since the Envisalink plugs into your router
      Cheers,
      Bob
        Not needing to be tied to a serial port may be enough for me to switch. I guess i will wait to see if any functionality is lost or gained first.
          I don't see anything being lost because it basically uses the same API as the IT-100. It just requires a login to the Envisalink to work which you can configure in the plugin
          Cheers,
          Bob
