My hometrollerSEL is not recognizing the devices or events in my Harmony Hub. I went through all the debugging I could, and am now stuck. I am getting this error:
Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Any ideas on how to fix this?
Here is a copy/paste of my log file.
Dec-21 7:08:48 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:08:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Dec-21 7:08:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:08p08
Dec-21 7:07:48 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:07:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Dec-21 7:07:08 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:07p07
Dec-21 7:06:48 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:06:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Dec-21 7:06:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:06p06
Dec-21 7:05:49 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:05:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Dec-21 7:05:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:05p05
Dec-21 7:04:49 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:04:48 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Dec-21 7:04:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:04p04
Dec-21 7:04:09 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
Dec-21 7:04:09 PM Harmony Hub Plugin: Harmony Hub OS type is 1
Dec-21 7:04:06 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
Dec-21 7:03:48 PM Plug-In Finished initializing plug-in Harmony Hub
Dec-21 7:03:48 PM Harmony Hub Plugin: Harmony Hub Architecture is: i686C
Dec-21 7:03:48 PM Harmony Hub Plugin: Harmony Hub Test CPU platform: Architecture: i686 CPU op-mode(s): 32-bit, 64-bit Byte Order: Little Endian CPU(s): 2 On-line CPU(s) list: 0,1 Thread(s) per core: 1 Core(s) per socket: 2 Socket(s): 1 Vendor ID: GenuineIntel CPU family: 6 Model: 55 Stepping: 8 CPU MHz: 2600.031 BogoMIPS: 3161.60 Virtualization: VT-x L1d cache: 24K L1i cache: 32K L2 cache: 1024K
Dec-21 7:03:48 PM Harmony Hub Plugin: Harmony Hub Running on Linux version
Dec-21 7:03:48 PM Harmony Hub InitIO called, plug-in is being initialized...
Dec-21 7:03:48 PM Info Plugin Harmony Hub has connected. IP:127.0.0.1:45300
Dec-21 7:03:40 PM Info Plugin Harmony Hub with instance: has disconnected
Dec-21 7:03:40 PM Plug-In Shutting down Plug-In: Harmony Hub
Dec-21 7:03:23 PM Harmony Hub Plugin: Harmony Hub Test Get Devices output for :Hub1: -
Dec-21 7:03:21 PM Harmony Hub Plugin: Harmony Hub Test Get Activities output for :Hub1: -
Dec-21 7:03:21 PM Harmony Hub Plugin: Harmony Hub OS type is 1
Dec-21 7:03:19 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:03:18 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
Dec-21 7:03:09 PM DSC Security Panel Response Processing response: LCD Update->90100032 Date Time DEC 20/17 5:03p03
Dec-21 7:02:19 PM Harmony Hub Error Exception in Hub_Polling_Timer_Elapsed : Conversion from string "" to type 'Integer' is not valid.
Dec-21 7:02:18 PM Harmony Hub Plugin: Harmony Hub Test Get Active Activity output for:Hub1: -
