RaspBee Premium - how do I add to JowiHue?
Originally posted by WhitW View PostApologies if this has been covered, my Google searches over last half hour have not turned up info needed..
I just received the RaspBee premium, and have installed on an RPi with the Deconz Jessie image. I *believe* it’s working.
I’ve gone into JowiHue confit and have scanned fro bridge, but nothing is coming up. Do I need to do some config on DeCONZ hub first?
Would appreciate any help with next step..
Open up deconz. Click on webapp (upper right corner). Log in with delight, delight. Upper right corner click on menu and settings. Click on unlock gateway. Go back to jowihue plugin and click on scan for bridge.
It should show up in the UI in a few minutes. If you want to rename it you can do it from the UI and it will transfer the name to deconz.
Originally posted by WhitW View PostThanks for reply, but I've done these things and still not getting anything... Looking at logs, it appears to see my Hue bridge, but not the DeCONZ...
Do i need to have a Zigbee device connected to RaspBee before it will connect????
There must be a non battery device connected first and they are referred to as routers. Battery devices are referred to as end devices and won't connect unless there is a router present.
Originally posted by WhitW View PostI've connected a Sengled Element Classic light, and I am able to control it through DeCONZ, but unfortunately, still no luck getting JowiHue to see the bridge...
The Gateway is only unlocked for 60 seconds (I don't see an option for extending). Is that long enough for JowiHue to see it?
Originally posted by WhitW View PostUnfortunately, all my other Zigbee devices are battery powered..
Scroll down this page and it gives a list of devices that work with deconz. Remember most or all sensors are battery. Need a switch or bulb or plug. https://github.com/dresden-elektroni...ported-DevicesLast edited by cowinger; April 9, 2018, 11:45 PM.
WhitW,
I think the version of deCONZ you are using will be an old version. Check this page for the latest version: https://www.dresden-elektronik.de/fu...are/pc/deconz/
With the "old" version the plugin will not find the raspbee, once you have upgraded it, it will be found by the plugin. Once you see the plugin has found the raspbee, then you have to go to the configuration page of the plugin, start registration and on the web app page of the raspbee you have to open the network in the settings. 30 seconds should be more then enough to allow the plugin to join the raspbee network. At this point no devices are needed yet, it should also find a empty deCONZ ZigBee network.
When you want to use the raspbee for mainly sensors, you still have to add a bulb. As cowinger discovered, the sengled lights seem not to function as routers. Also in your image the sengled is showing as end device (a router has a yellow bar on the left). So you need to find at least one cheap light you can use (IKEA/Osram/Philips/GE etc). After adding this light, check on the yellow bar.
Also, when you plan to use sensors on a remote location from the raspbee or the extra light, you might need extra lights as the sensor needs to be reachable. But that is something you should be able to check in the deCONZ interface as the line colors are giving an impression on the quality of the connections. Green being good and red being bad, with different shades in between.
Wim-- Wim
WhitW,
Thanks for confirming it works now
Have fun!
Wim-- Wim
Guest
I just have sensors (3 hue motions ans 3 xiaomi) and was able to add them to deconz and i use them in homeseer. should i buy a hue bulb if i want to add more sensors?
MattLau,
The developers of deCONZ do advise to have at least one bulb, or plug in the network. It can be a Hue bulb (those are the most reliable) or also other brands like GE, CREE or osram
The point seems to be is that the gateway at certain point not repond to direct conections from battery operated devices. An extra router (like a bulb or plug) will then correct this.-- Wim
