SaveState RestoreState
    #16
    Ab8ss
    UPDATE : It seems to be related to the VB engine, is this possible ?
    CPU goes berzerk ( 100% ) after a couple seconds so something must be loop in some process, Ipitman, any clue ?
    Thx !
      #17
      Thx !
      Sounds alot like a hardware issue What hardware are you running HS on? Is this the same HomeTroller you've been reporting issue with?
        #18
        Thanks Rupp, I am not sure what to say at this point...I can't find anything wrong with the plug-in...and I use the AB8SS engine I wrote as one of my primary plug-ins...all phone calls, announcements, everything uses this engine...so I would know if it is broken. That being said, I do not want to discount that someone might find an environment that things get a bit complicated...so I am willing to help diagnose issues...but in this case the log file shows normal operation. CPU, memory, and other processes I could not comment on, so I just do not know what to suggest next.
        -Larry
        A member of "The HA Pioneer Group", MyWebSite
        Plugins:
        VWS, AB8SS, lrpSpeak, Calendar, Arduino, Harmony, BlueIris, Sprinklers, ZipBackup...
        Hardware:
        Intel NUC8i7BEH1 running Windows 10 Pro headless, HS3 Pro, Plex running on Synology dual High Availability DS-1815+ NAS (24Tb each), Synology Surveillance Station running on DS-416 Slim (8Tb), Samsung SmartThings, Google Home, Alexa, Hubitat Elevation, ZNET, Ubiquiti UniFi Network, Davis Vantage Pro II Weather Station. Whole house speaker system using a couple of AB8SS switches. Vantage Pro II Weather Station, Rain8Net Sprinklers, Hubitat Elevation, Google Home, Alexa, DSC Security System, Ubiquiti UniFi Network.
          #19
          ab8ss
          No hard feelings Larry, I understand it is not necesserily a plugin issue but it drives us crazy as we have litteraly done everything possible, I am afraid formatting and restoring HS will have same result but I guess we will have to try.
          Rupp : No, this one is our main server @ our office which annouces all inbound calls as well as manage radio and intercoms. I guess it will call for an early yearly maintenance
          Thx guys, this all goes in the learning curve to a neverending debugging world. Maaannn Do we loooOooove debugging !!
          Ciao...
            #20
            Sorry for your problem...wish I knew what to tell you. Good luck with the maintenance.
            -Larry
            Plugins:
            Hardware:
