USB Mini External Modem Recommendations
    I am looking for a mini USB modem to replace the previously recommended Rosewill modem.
    Has anyone tried any of the following modems?
    Zoom 3095-00-00G 56Kbps USB Mini External Modem
    U.S. Robotics USR5637 56Kbps USB High-performance V.92 modem
    Aluratek FileMate AWUM100F 56Kbps USB Mobile Modem
    StarTech USB56KEM2 56Kbps USB V.92 Fax Modem
    TRENDnet TFM-560U 56Kbps USB High Speed Fax Modem
    Ultrajones
    Hey if you get another modem working with homeseer, please let us know. The THREE HUNDRED dollar solution available now is just not right fir me.
    Transitioning to HS3Pro .298 - WinXPEmbedded
      Trendnet OK Maybe - old post
      I came across this old post which seems to talk about the Trendnet 560U - looks like maybe there was a problem but that you did a work-around in the plug-in to address it?
      http://forums.homeseer.com/showthread.php?t=140783
      Maybe the original author has more to add now that it's been several months.
        I sent an e-mail to all vendors above and only Zoom replied stating their modem supports caller ID in the US. I plan on picking up the Zoom 3095-00-00G 56Kbps USB Mini External Modem at BestBuy today and will test it with the UltraCID HSPI.
        Ultrajones
          Ultrajones
          Right on!!!
          I look forward to your findings...
            Me also !
            Oh Oh - just looked thru the reviews on BB site
            "This is strictly a dial up modem. It has no telephone capability. My previous modems would function with various software programs for telephone dialing. This does not. Zoom support very slow but to the point. "This device will not do what you want it to do.""
            Good luck...................
            Neil
            Newmarket Ontario
              Zoom 3095-00-00G 56Kbps USB Mini External Modem Works!
              I purchased the Zoom 3095-00-00G 56Kbps USB Mini External Modem from best buy. On my Windows 7 system, I just plug in the modem and let windows install the default drivers.
              The modem supports caller ID, was able to drop a call and properly reported when a handset went off hook and on hook.
              Ultrajones
                EXCELLENT!!!
                Does it work with HSPhone?
                  Originally posted by Dafunktyfunk View Post
                  EXCELLENT!!!
                  No.
                    Curious
                    Just curious - was Zoom the only company to reply...or the only reply that confirmed CID compatibility?
                    If other companies replied but either didn't mention CID or said directly that they don't support it, which ones?
                    this is just for my own info on other projects. Curious as to which companies were forthcoming and replied honestly saying they didn't do CID vs. those that didn't bother to reply at all and or declined to reply on point as to the CID capabilities.
                      Zoom was the only company to reply.
                      Ultrajones
                        I purchased a U.S. Robotics USR5637 56Kbps USB High-performance V.92 modem today, and wanted to report that it also works.
                          I got a :
                          USB 56k MODEM External FAX V.92 V92 Conexant 93010
                          on ebay:
                          http://shop.ebay.com/?_from=R40&_trk...All-Categories
                          for about 15bucks and it works great with this plugin.
                          Raptor
                          HS3 Pro on Windows 8 64bit
                          53 Z-wave nodes(46 devices, 7 remotes), 15 DS10a's, 10 ms16a's, 9 Oregon Sensors, W800, RFXCOMtrx433, Way2Call, 3 HSTouch Clients, 2xRussound CAS44, Global Cache GC100-12,10 Rollertrol blinds(+ zwave) ,3 Squeezebox Radios and 1 Squeezebox Boom,DMX Arduino via ethernet,Rain8Net,3x Echo Dot's
                          Check out my electronics blog here:
                          https://www.facebook.com/RaptorsIrrationalInventions
                            bump, so the working modem discussion stays prominent
                              I use huawei usb modems, the price is a little high, but it deserves.
