Just got 2-GC100 units and got them both registered in HomeSeer last night. Started learning IR using iLearn and I can control my receiver on/off/source just fine.
My question is this:
Is there any way to control the length of time that the IR command is sent? I have a Yamaha receiver and the volume requires a lengthy press to make any real changes. The IR code learned required me to repeat the IR multiple times to make any noticable changes to the volume.
Should I try to learn the IR while holding the volume button? It seems to produce a different IR in iLearn but I haven't tried that.
I tried changing the timing to 100 on the IR code but that doesn't seem to help much.
Thanks in advance.
Chris
Thanks in advance.
Chris
