Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old June 3rd, 2014, 07:46 AM
IGG IGG is offline
Zones not activating in HS2 or HS3
I just installed the EZflora device and it works fine using the simplyhomenet utility. However, the zones will not activate using either HS2 or HS3. My configuration is a simple 3 zone setup with a pump.
The devices seem to show properly is Homeseer.
Old June 3rd, 2014, 09:10 PM
skozin's Avatar
skozin skozin is offline
I had the same problem. What I did was delete the device, then shutdown Homeseer, then reinstall the device, which will recreate all of the zones. The only thing that now is not working for me is the configuration page where I push one of the 5 buttons and nothing happens.
FYI I am still using the older plugin 1.1.2.0. I will try to upgrade to the newer version tonight and see what happens.
Any suggestions?
Steve
Old June 3rd, 2014, 09:59 PM
IGG IGG is offline
Fixed
It turns out my issue was I created the EzFlora device in the Insteon Plugin first instead of the EzFlora plugin. Works fine now.
Old June 4th, 2014, 07:30 AM
hurry4it hurry4it is offline
ICG,
I'm glad it is working now, let me know if there are any additional problems.
skozin,
Let me know if the newer version doesn't solve the problem. There were some bugs in the early versions with the configuration page buttons. You may need to delete and re-add the device when upgrading to the newer version.
Adam
Old June 4th, 2014, 08:13 AM
skozin's Avatar
If I am not using HS3 yet, How can I download the latest update for HS2?
Steve
Old June 5th, 2014, 10:28 AM
Steve,
I just realized that you listed you were using version 1.1.2.0. This is the latest released version for HS2. Can you provide some additional information on what configuration buttons are not working so I can look into the issue. Also, please post the log with the plugin set to debug logging so I can review that.
Adam
Old June 5th, 2014, 10:42 AM
skozin's Avatar
It is on the configuration page, when I click any of the buttons on that page. The 5 buttons for Manual timers and Program timers.
Here is a snippet of the log when I pressed one of the butttons:
6/5/2014 9:54:56 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:01 AM EZFlora Debug Entered PagePut() function.
6/5/2014 9:55:01 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:05 AM EZFlora Debug Entered PagePut() function.
6/5/2014 9:55:05 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:06 AM SageInsteonTStat Received Insteon Data: 01 01 DE 2D 0F D4 EF 27 45 00
6/5/2014 9:55:06 AM SageInsteonTStat Received Insteon Data: ACK 45 00 01 01 DE 2D 0F D4 EF 27 45 00
6/5/2014 9:55:06 AM SageInsteonTStat ACK Command Received
6/5/2014 9:55:06 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01 01 DE 2D 0F D4 EF 27 45 00
6/5/2014 9:55:06 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = ACK 45 00 01 01 DE 2D 0F D4 EF 27 45 00
6/5/2014 9:55:06 AM SageInsteonTStat Received Insteon Data: 01 01 DE 2D 0F D4 EF 12 41 00 1E 1E 1E 1E 1E 1E 1E 1E 00 00 00 00 00 00
6/5/2014 9:55:06 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01 01 DE 2D 0F D4 EF 12 41 00 1E 1E 1E 1E 1E 1E 1E 1E 00 00 00 00 00 00
6/5/2014 9:55:06 AM EZFlora Debug Entered Timeout() subroutine.
6/5/2014 9:55:06 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:44 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:49 AM Event Event Trigger "Jon00s Check Email"
6/5/2014 9:55:49 AM Event Running script in background: CheckEmailPOP_V3_HS2.vben("main","normal")
6/5/2014 9:55:52 AM EZFlora Debug Entered PagePut() function.
6/5/2014 9:55:52 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:54 AM EZFlora Debug Entered PagePut() function.
6/5/2014 9:55:54 AM EZFlora Debug Entered GenPage() function.
6/5/2014 9:55:55 AM SageInsteonTStat Received Insteon Data: 01 01 DE 2D 0F D4 EF 27 45 01
6/5/2014 9:55:55 AM SageInsteonTStat Received Insteon Data: ACK 45 01 01 01 DE 2D 0F D4 EF 27 45 01
6/5/2014 9:55:55 AM SageInsteonTStat ACK Command Received
6/5/2014 9:55:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = ACK 45 01 01 01 DE 2D 0F D4 EF 27 45 01
6/5/2014 9:55:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01 01 DE 2D 0F D4 EF 27 45 01
6/5/2014 9:55:55 AM SageInsteonTStat Received Insteon Data: 01 01 DE 2D 0F D4 EF 12 41 01 05 05 05 05 0A 0A 0A 0A 00 00 00 00 00 00
6/5/2014 9:55:55 AM EZFlora Debug HSEvent EV_TYPE_GENERIC Case: Parms = 01 01 DE 2D 0F D4 EF 12 41 01 05 05 05 05 0A 0A 0A 0A 00 00 00 00 00 00
6/5/2014 9:55:55 AM EZFlora Debug Entered GenPage() function.
Steve
Old June 5th, 2014, 03:35 PM
Steve,
According to the log, the button pushes are being recognized and the Insteon traffic is being sent requesting the timer values. The response for the timer values is received shortly thereafter and then it looks like the page is generated which is weird since it must be just re-generating the config page instead of going into the timer page.
Have you restarted HS and your HS server in a while? I can't think of any reason why the page wouldn't be generated properly after getting the Insteon response...
Let me know if restarting helps at all.
Adam
Old June 6th, 2014, 07:22 AM
skozin's Avatar
Update:
I reinstalled it and restarted Homeseer and now the page is showing up. Thanks.
Now I have another issue. I have 9 zones and am using the EZFlora for zones 1-8. For zone 9 I was going to use a 2450 I/O linc, but for some reason I can't seem to get it to work. I saw the diagram from smarthome, but that doesn't seem to work. Can someone give me a diagram of how it should be connected.
This is how I thought it should be done.
Power supply (24 VAC) to N/O on I/O Linc
Common to Common on Sprinkler valve and I/O Linc
Zone 9 Wire (I don't know where it should go on the I/O linc
I have the I/O Linc set to Continuous
Please help (It is so confusing) When I used the Universal Module from X10 All I connected was a Common wire and Zone 9 wire and it worked fine.
Steve
Old June 6th, 2014, 07:39 AM
sparkman's Avatar
sparkman sparkman is offline
Hi Steve, the diagram from Smarthome is correct. One side of the AC supply should be connected to the valve and the other is switched at the IOLinc by the COM and NO contact. COM on the iolinc doesn't mean common ground. It's the common contact of the double throw switch in the iolinc.
Cheers
Al
Old June 6th, 2014, 09:15 AM
skozin's Avatar
Yeah I figured it out right after I posted it. I just used the same 2 wires I had from the Universal Module and The sprinkler valve zone on N/O and Common to common on the sprinkler valve. I think I didn't have my 2450 I/O linc set correctly to Continuous.
Now it is working.
Steve
Activating PGM's CeeTee BLDSC (3P) 4 February 26th, 2014 08:44 PM
Task not activating from HS sforeman00 Elk M1 Plug-In 2 December 23rd, 2006 06:46 PM
VR gone wacky after activating WEB access stanb17 Web Server and Interface 3 December 12th, 2003 08:06 AM
VR gone wacky after activating WEB access stanb17 Web Server and Interface 0 January 1st, 1970 12:00 AM
