Go Back   HomeSeer Message Board > Irrigation Plug-ins > Irrigation Discussion > EZFlora Insteon Irrigation Controller Plug-in
EZFlora Insteon Irrigation Controller Plug-in Discussions of Adam Telford's EZFlora Insteon Irrigation Controller Plug-in
Old May 30th, 2016, 01:34 AM
krufka krufka is offline
Cool EZFlora - not working
i am trying to run this plugin but no luck :/ anyone knows what is wrong here?
here is my log. HS3 Pro Edition 3.0.0.280 (Windows) / plugin 2.0.0.1
May-30 01:41:42
EZFlora Info Insteon Plugin Not Ready May-30 01:41:42 EZFlora Debug Entered RegisterDevices() subroutine. May-30 01:41:40 EZFlora Info Insteon Plugin Not Ready May-30 01:41:40 EZFlora Debug Entered RegisterDevices() subroutine. May-30 01:41:38 EZFlora Info Insteon Plugin Not Ready May-30 01:41:38 EZFlora Debug Entered RegisterDevices() subroutine.
Old May 31st, 2016, 09:25 AM
hurry4it hurry4it is offline
What version of the mnsandler Insteon Plugin do you have and is the plugin enabled?
Adam
Old May 31st, 2016, 11:47 AM
Adam
Adam, do you mean the HSInsteon plugin? It is 1.0.0.9 .... it is enabled, i am able to control lighting fine.It is teh free version that is included in HS3 PRO ... should I get this instead? http://store.homeseer.com/store/MNSa...HS3-P1679.aspx
THanks!
Old June 1st, 2016, 08:09 AM
SOLVED
enabling mnsandler Insteon Plugin worked, thanks!
Old June 1st, 2016, 04:34 PM
Glad you got it working. The mnSandler Insteon plugin is required for the EZFlora plugin to work. It will not work with the free HomeSeer Insteon plugin.
Adam
Old July 18th, 2017, 05:14 PM
thetaz01 thetaz01 is offline
I tried Making a new thread for my issue but it seems the site kept asking me to login even after I am logged in...
I am running EZ Flora v 2.0.0.1
And I just got sod put down, and am trying to setup the manual timers, and trhe program timers..
I set program 1 timers to 90 mins for 4 zones, and 0 for the rest, as I only have 4 zones..
and now I cant get into ANY timers to check that they are set..
If I edit the device, and select manual timers, or even program 1 timers.
it says loading timer data, screen flashes twice saying loading timer data, then comes back with...
Error getting timer data
edit 1 program timers
and its empty
Reload or cancel
PLEASE HELP ASAP < I just got SOD put down and I need to make sure my sprinklers are watering properly..
here is the debugging log turned on then tried changing program 1 timer
Jul-18 5:13:55 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = main_loglevel=1&id=main_save&main_save=Submit user = Taz userRights = 6
Jul-18 5:13:53 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring =
Jul-18 5:13:53 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = &id=editdevice_cancel&editdevice_cancel=Submit user = Taz userRights = 6
Jul-18 5:13:48 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = editdevice
Jul-18 5:13:48 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = &id=loading_cancel&loading_cancel=Submit user = Taz userRights = 6
Jul-18 5:13:45 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = action=timeout user = Taz userRights = 6
Jul-18 5:13:40 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = loading
Jul-18 5:13:40 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = action=timeout user = Taz userRights = 6
Jul-18 5:13:37 PM EZFlora Debug HSEvent GENERIC Case: Parms = ACK 44 02 01 3D D1 D9 33 5F 1C 2F 44 82
Jul-18 5:13:37 PM EZFlora Debug Entered HSEvent GENERIC Case
Jul-18 5:13:37 PM EZFlora Info EZFlora 3D.D1.D9 all programs off
Jul-18 5:13:37 PM EZFlora Debug Entered ProcessProgramsOff() subroutine.
Jul-18 5:13:37 PM EZFlora EZFlora 3D.D1.D9 valve 3 active
Jul-18 5:13:37 PM EZFlora Debug Entered ProcessValveStatus() subroutine.
Jul-18 5:13:37 PM EZFlora Debug HSEvent GENERIC Case: Parms = 01 3D D1 D9 33 5F 1C 2F 44 82
Jul-18 5:13:36 PM EZFlora Info Configuration Status: Rain Sensor Enabled: False Rain Detected: False Broadcast Meter Messages: False Broadcast Valve Messages: False Daignostic Mode Enabled: False
Jul-18 5:13:36 PM EZFlora Debug Entered ProcessConfigRegister() subroutine.
Jul-18 5:13:36 PM EZFlora Debug HSEvent GENERIC Case: Parms = 01 3D D1 D9 33 5F 1C 2F F0 00
Jul-18 5:13:36 PM EZFlora Debug Entered HSEvent GENERIC Case
Jul-18 5:13:36 PM EZFlora Debug HSEvent GENERIC Case: Parms = ACK F0 00 01 3D D1 D9 33 5F 1C 2F F0 00
Jul-18 5:13:36 PM EZFlora Info Polling DEVICE 1 with address of 3D.D1.D9
Jul-18 5:13:36 PM EZFlora Debug Entered TimedPoll() subroutine.
Jul-18 5:13:35 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = loading
Jul-18 5:13:35 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = action=timeout user = Taz userRights = 6
Jul-18 5:13:35 PM EZFlora Debug Entered HSEvent GENERIC Case
Jul-18 5:13:30 PM EZFlora Debug HSEvent GENERIC Case: Parms = ACK 45 01 01 3D D1 D9 33 5F 1C 2B 45 01
Jul-18 5:13:30 PM EZFlora Debug Entered HSEvent GENERIC Case
Jul-18 5:13:30 PM EZFlora Debug HSEvent GENERIC Case: Parms = 01 3D D1 D9 33 5F 1C 2B 45 01
Jul-18 5:13:30 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = loading
Jul-18 5:13:30 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = &id=editdevice_program1&editdevice_program1=Submit user = Taz userRights = 6
Jul-18 5:13:28 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring = editdevice
Jul-18 5:13:28 PM EZFlora Debug Entered postBackProc() function with the following parameters: page = EZFlora data = DEVICE1=checked&cb_DEVICE1=on&id=main_edit&main_edit=Submit user = Taz userRights = 6
Jul-18 5:13:25 PM EZFlora Debug Entered GenPagePlugin() function with the following parameters: pageName = EZFlora user = Taz userRights = 6 querystring =
Old July 19th, 2017, 11:28 AM
Please see my response to your other post.
Adam
EZFlora + mcsSprinklers + HS3? Jingoro mcsSprinklers 1 May 15th, 2014 07:59 PM
EZFlora and HS3 ? nfrobertson EZFlora Insteon Irrigation Controller Plug-in 2 August 7th, 2013 10:38 AM
EZFlora stopped working brianjhomeseer EZFlora Insteon Irrigation Controller Plug-in 3 July 18th, 2013 07:06 PM
EZFLora stopped working gregtee EZFlora Insteon Irrigation Controller Plug-in 2 March 22nd, 2013 12:04 PM
My EZFlora keeps inhibiting... codemonkey EZFlora Insteon Irrigation Controller Plug-in 24 November 11th, 2012 05:03 AM
