I installed Zseer+ and tested my network. All nodes fail with the response test. The command test pass with no failed commands but not a single response goes through, I get an error:
Testing node 8...
Issue getting node level : Timeout OK
I get this error for every node but only for response tests. I use an HS3 ZEE S2 Edition 3.0.0.318 with version 3.0.1.130 of the zwave plugin.
Any suggestions on how to fix this?
Testing node 8...
