Hi Mark,
I am having issue where my Micro Module won't open or close when sending commands from HS.
If I operate it manually the status is sent back correctly to HS.
Here is some info about the device:
Device Type: Micro Module Open/Close
Firmware Version: 43
Comm Reliability: 100% (7 failed out of 3131 cmds)
Link #2 Load has local control reporting to HomeSeer
Link #1 Load is controlled by HomeSeer using RF PLM Group #0 (i2CS Registration Link) - Command: Off
Link #3 Load is controlled by HomeSeer using RF PLM Group #254 (HomeSeer All Devices Group) - Command: On
LED Flash on Tx : Disabled
LED: Off
Key Beep: Off
Switch Type: Dual Momentary
3 Way: Enabled
Other than that the plugin works great with all my other devices so far.
Mathieu
LED: Off
Key Beep: Off
3 Way: Enabled
Nov-27 14:31:08 Insteon Received message from Arrière couvert SPA (1F.DC.B3) taking hops: 1 Nov-27 14:31:08 Insteon Wait: Found a matching Insteon raw message: 01 1F DC B3 2F B5 B9 2B 11 00 Nov-27 14:31:08 Insteon Received STX 0x50 (Raw Insteon Rec):1F DC B3 2F B5 B9 2B 11 00 Nov-27 14:31:08 Insteon ..Time to send message: 28.7101 Nov-27 14:31:08 Insteon ..Got RF PLM Response 02 62 1F DC B3 0F 11 00 06 Nov-27 14:31:08 Insteon Sending command 02 62 1F DC B3 0F 11 00 to RF PLM, (Expecting 0 bytes extra back) Pre-Payload ACK:False, NAK is ok:False Nov-27 14:31:08 Insteon Setting status and value for device 1F.DC.B3:1. Old status:0 Old Value:0, New Status:3 New Value:0 Nov-27 14:31:08 Insteon CAPIControl: Label=Open, Value=100, ControlType=Button Nov-27 14:31:08 Device Control Device: Extérieur Arrière couvert SPA to Open (100) by/from: CAPI Control Handler
Mathieu
