Save device state to a variable?
    I feel like I'm blind because I don't see this but is it possible as an event step, to save the current device state to a variable? So that I can have it change to On for example, and then return to like 25% or whatever it was at? Just wondering if this can be done with the web interface or if it needs scripting. Thanks!
    I'm not 100% sure, but the Easy Trigger plug-in may permit you to do this without scripting.
      ... and I have just written a script to save and restore states.
      The whole idea behind the script is that a wife of another forum user wanted HomeSeer to remember the light setting as it was right now, so she later could just restore them after they had been turned off.
       Sub Main(ByVal not_used As Object)
              'By Moskus, August 2015
              'Set up a new config.
              'Specify devices between the brackets below (comma separated):
              Dim devices() As Integer = {342, 872, 873}
              'Specify a configuration name. This is used when calling "Save" and "Load" later.
              Dim config_name As String = "Bedroom"
              'Creating initial ini file and store it in a list
              Dim lst As New System.Collections.Generic.List(Of DeviceState)
              For Each d As Integer In devices
                  Dim dS As New DeviceState
                  dS.deviceRef = d
                  dS.deviceValue = hs.DeviceValueEx(d)
                  lst.Add(dS)
              Next
              'Write the list to file
              SaveToFile(config_name, lst)
          End Sub
          Sub Save(ByVal config_name As String)
              'Get the device list
              Dim lst As System.Collections.Generic.List(Of DeviceState) = LoadFromFile(config_name)
              'Get the current device values for each device
              For Each d As DeviceState In lst
                  d.deviceValue = hs.DeviceValueEx(d.deviceRef)
              Next
              'Store the list
          End Sub
          Sub Load(ByVal config_name As String)
                  'Find the correct CAPI based on device value...
                  Dim CAPIcontrol As HomeSeerAPI.CAPIControl = Nothing
                  For Each cc As HomeSeerAPI.CAPIControl In hs.CAPIGetControl(d.deviceRef)
                      If d.deviceValue = cc.ControlValue Then
                          CAPIcontrol = cc
                          Exit For
                      End If
                  Next
                  '... And execute it
                  hs.CAPIControlHandler(CAPIcontrol)
              Next
          End Sub
          Function LoadFromFile(ByVal config_name As String) As System.Collections.Generic.List(Of DeviceState)
              Dim filename As String = "DeviceState_" & config_name & ".ini"
              Dim lines() As String = hs.GetINISectionEx("Devices", filename)
              For Each line As String In lines
                  Dim deviceRef As Integer = line.Split("=")(0).Trim
                  Dim deviceValue As Double = line.Split("=")(1).Trim
                  lst.Add(New DeviceState(deviceRef, deviceValue))
              Next
              Return lst
          End Function
          Sub SaveToFile(ByVal config_name As String, ByVal stateList As System.Collections.Generic.List(Of DeviceState))
              For Each d As DeviceState In stateList
                  hs.SaveINISetting("Devices", d.deviceRef, d.deviceValue, filename)
              Next
          End Sub
          <Serializable>
          Public Class DeviceState
              Public Property deviceRef As Integer
              Public Property deviceValue As Double
              Public Sub New()
              End Sub
              Public Sub New(ByVal _deviceRef As Integer, ByVal _deviceValue As Double)
                  Me.deviceRef = _deviceRef
                  Me.deviceValue = _deviceValue
              End Sub
          End Class
      There are two ways of setting it up. 1) You could either edit the "Main" sub (change the parameters "config_name" and "devices") and run the Main sub, OR 2) you could just make the ini-file yourself. The contents should be on this format:
      [Devices]
      deviceReference1=deviceValue1
      deviceReference2=deviceValue2
      deviceReference3=deviceValue3
      ... and so on
      ... so for my bedroom at night it looks like this:
      [Devices]
      342=53
      872=25
      873=39
      Then you just set up an even like this:
      (... but use Load instead of Save)
      This makes a quick and dirty way to create basic scenes. The script only reads the device value for a device and sets the device to that value, so you could easily create different scenes like "Bedroom-Morning", "Bedroom-Sexytime", "Bedroom-Night", "Bedroom-Off", etc.
        With the Easy Trigger plugin you can create a virtual device and then save the state of another device to this virtual device using the action "Set Device to another Device"
